Watchdog problem
I have a AMD computer and it hangs on shutdown and reboot ”watchdog and britty it stands” and after a long time the computer shutdown or reboots.
I have ”nowatchdog” in grub
Some one knows howe to solved it?
sudo pacman -Rc brltty
sudo dracut-rebuild
It will not be helpful until after you reboot.
Be sure you are OK with the list of packages being removed with pacman -Rc brltty before confirming.
Thank you, I just downloaded a new .iso and reinstall it and now it is all good.
Thank you again for your reply.
