Warning: directory permissions differ on ead and iwd
Today while updating via sudo pacman -Syu the following warnings were displayed:
[2019-08-30 10:03] [ALPM] warning: directory permissions differ on /var/lib/ead/
filesystem: 750  package: 700
[2019-08-30 10:03] [ALPM] warning: directory permissions differ on /var/lib/iwd/
[2019-08-30 10:03] [ALPM] upgraded iwd (0.19-1 -> 0.20-1)
Unless someone knows a good reason why the permissions on those two directories should be manually changed, I will ignore the warnings for now. Security issue?
it is something upstream, or packager… can be a bug, there can be a reason for it.
actually i dont know. But this can happend on every upgrade.
iwd is a wireless daemon but ead i dont know. i would not change it, mayby down to road you get some errors back on a update
Look here for more information on what ead does
Pudge
