Cant select that feature coz its grayed out. Any ideas ?
but it should be solved already, BUG is old… and installing python2-pygame is not solving this here…
i try python-pygame now —> and yea it is working…
sudo pacman -S python-pygame
Thanks a lot. Its working after installing python-pygame.
Did you test if Deluge is actually playing the selected sound file after a download is complete ?
What format of sound file are you using ? WAV or MP3 ?
I used a MP3 & tested by finishing a download and it worked.
