and why do you removed lightdm?
i could try it again, with my timeshift in btrfs is this possible.
When you remove lightdm you can watch bootlog better. And i saw that firewalld was still active. who needs lightdm really at homepc?
bootlog ? the bootlog is running before lightdm as in state of DM system is booted already ![]()
But indeed on a single user system you do not need a “Login Manager” that runs in the background all the time eating your resources ![]()
Now i double-check the problem:
The solution is : if you install ufw you must remove firewalld and dont enable iptables.service.
only with both it will work - autostart ufw
