Other than virtualbox itself and guest options, what else do I need to install for it to run smoothly?
I could never get it to run without it crashing on Manjaro, so maybe I’m missing something?
I would recommend virtualbox
and virtualbox-host-dkms
If you are running a Windows guest, virtualbox-guest-iso
can also be useful.
Thanks, will add them now.
On the host what @dalto said.
On the guest install virtualbox-guest-dkms and virtualbox-guest-utils unless you already have them.
Thanks, I will check. In the meantime, how do I exit full screen mode? What’s the host key?
I’m not at linux box now, but i think it is right-Ctrl.
Yep, that’s it
