I installed the new ISO to a VM, the host is Windows 10, and I installed the guest additions, but they don’t seem to work. I was able to get the shared folders working, but the drag-and-drop and clipboard, they simply don’t want to work. I try to activate them manually, but still nothing happens.
Has anyone the same problem, or has tried to work this around?
look if you have this installed : pacman -Qs virtualbox
for the guest offcourse in the vbox
community/virtualbox-guest-iso 6.1.12-1
The official VirtualBox Guest Additions ISO image
community/virtualbox-guest-utils 6.1.12-3
VirtualBox Guest userspace utilities
Hi,
I followed the instructions mentioned in the guide, and I have confirmed virtualbox is installed. Some of the services, like drag-and-drop, seems to be running, but they don’t work because I have tried them. I double checked that i have them selected in Devices in the host. I have them selected. I also tried to manually launch through VBoxClient, but although it does not throw an error, it doesn’t do anything.
