Uuid on second drive
Hello
What would cause the uuid on a drive to change? I have a second ext4 drive mounted automatically in my fstab. Today my computer wouldn’t boot, so I had to go in and comment out the drive in fstab. Found out that the uuid had changed and once I put the new uuid in fstab it booted fine.
Did it change spontaneously? I never heard of such an occurrence.
Formatting a partition would change the UUID else I don’t know.
https://www.startpage.com/sp/search?query=What+would+cause+the+uuid+on+a+drive+to+change%3F&cat=web&pl=opensearch&language=english
You know I bet that was it. I forgot that I had reformatted the drive. Thanks
for non-essentail drives (read not / and not /home mount points) I add the nofail to the fstab entries.
That way the system boots even if the drive is no longer accessible.
Related to boot problems, have you checked the contents of /boot/grub/grub.cfg (assuming you use grub)? That file uses UUIDs too.
Edit: re-read you later post, seems that the problem is already solved.
Could you mark the solving post by another forum-member as solution, please? - Thanks.
