Hey! I am using i3 with EOS and I wanted to know whether it is possible to use the same output device for all applications (and be able to switch it), instead of manually configuring it every time.
Can you be a bit more specific?
arandr
helps you to create e.g. monitor.sh in .screenlayout directory (select primary monitor, apply, Save as monitor.sh and chmod a+x monitor.sh )
xrandr --output eDP1 --primary --mode 1920x1080 --pos 0x0 --rotate normal --output HDMI1 --mode 1600x900 --pos 1920x0 --rotate normal --output VIRTUAL1 --off
If you mean workspaces then comment out in
.config/i3/config
these lines, or such
# bind program to workspace and focus to them on startup:
assign [class="Xfce4-terminal"] $ws1
assign [class="(?i)firefox"] $ws2
assign [class="Thunar"] $ws3
assign [class="thunderbird"] $ws4
assign [class="TelegramDesktop"] $ws5
I am horribly sorry. I haven’t been clear and missed it.
I meant audio output.
The only thing I know about audio mixers that
pulsemixer
stores the settings ( and HDMI output is also managed by pulseaudio)
So wait for more knowledgeable people for a nice and correct solution.
My ugly one:
yay -S pulseaudio
accept with y to replace pipewire
yay -S pulsemixer
systemctl --user stop pipewire.socket
systemctl --user stop pipewire.service
systemctl --user start pulseaudio.service
systemctl --user start pulseaudio.socket
pulsemixer
select your preferred card/channel with F3
Thanks! I’ll try to look at it!
