So recently I was thinking about switching to BTRFS on my main SSD with the OS. I also have a secondary HDD where I store my games. Currently both the SSD and HDD use ext4.
Now my question is: Can I format the HDD to also use BTRFS like my SSD or is it not possible? If I can, what’s the best method to do it?
Or maybe I shouldn’t do it and you think it is better to use a mix of BTRFS[SSD] and ext4[HDD]?
I use almost exclusively BTRFS, with extensive snapshots, excepting only my VMs partition (EXT4). That being said, if your current setup is working, then why change it? Unless you’re going to make use of BTRFS’s features, then I recommend standing pat.
Ok, so if I wanted to use gnome-disks for that, can I choose the BTRFS option there? It says “btrfs for snapshots” in the options and I wasn’t sure if it is still viable for general purpose usage or only for snapshots
