Using gnome-software centre repos
Not good enough to charge someone money to install on their computer. If the customer needs a nearly fail proof gui helper/installer, an arch based distro is not a very good place to be.
Search pamac here and you can see all the help threads.
While I have not had any issues using it in EOS I do use pacman to upgrade.Other than Chrome I have no other packages from the aur other that pamac so I do use pamac to upgrade those.Iā€™m getting older and it helps me to be able to use a gui although I can use the terminal when I have to.
