Is it possible to make checkupdates
“read” from a custom-made pacman.conf? I would like to make a conf file for the testing repo and pass it to checkupdates to see what updates are available in Testing.
I know of --config /path/to/file.conf
for pacman. But I am not sure if i use pacman -Syu, would that “mess up” my local database.
I have looked at the code for /usr/bin/checkupdates
but it is above my knowledge to make any changes there.
cat /usr/bin/checkupdates
!/usr/bin/bash
checkupdates: Safely print a list of pending updates.
Copyright © 2013 Kyle Keen keenerd@gmail.com
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see http://www.gnu.org/licenses/.
declare -r myname=‘checkupdates’
declare -r myver=‘1.4.0’
LIBRARY=${LIBRARY:-’/usr/share/makepkg’}
DOWNLOAD_CACHE=0
USE_COLOR=0
Import libmakepkg
source “$LIBRARY”/util/message.sh
source “$LIBRARY”/util/parseopts.sh
usage() {
cat << EOF
${myname} v${myver}
Usage: ${myname} [options]
Options:
-d, --download download pending updates to the pacman cache.
-h, --help display this help message and exit.
Note: Export the “CHECKUPDATES_DB” variable to change the path of the temporary database.
EOF
OPT_SHORT=‘dh’
OPT_LONG=(‘download’ ‘help’ ‘nocolor’)
if ! parseopts “$OPT_SHORT” “${OPT_LONG[@]}” – “$@”; then
exit 1
fi
set – “${OPTRET[@]}”
unset OPT_SHORT OPT_LONG OPTRET
while :; do
case $1 in
-d|–download)
DOWNLOAD_CACHE=1 ;;
-h|–help)
usage
exit 0 ;;
–nocolor)
USE_COLOR=‘n’;;
shift
break ;;
esac
shift
done
check if messages are to be printed using color
if [[ -t 2 && $USE_COLOR != “n” ]]; then
colorize
else
unset ALL_OFF BOLD BLUE GREEN RED YELLOW
fi
if ! type -P fakeroot >/dev/null; then
error ‘Cannot find the fakeroot binary.’
exit 1
fi
if [[ -z $CHECKUPDATES_DB ]]; then
CHECKUPDATES_DB="${TMPDIR:-/tmp}/checkup-db-${UID}/"
fi
trap ‘rm -f $CHECKUPDATES_DB/db.lck’ INT TERM EXIT
DBPath="$(pacman-conf DBPath)"
if [[ -z “$DBPath” ]] || [[ ! -d “$DBPath” ]]; then
DBPath="/var/lib/pacman/"
fi
mkdir -p “$CHECKUPDATES_DB”
ln -s “${DBPath}/local” “$CHECKUPDATES_DB” &> /dev/null
if ! fakeroot – pacman -Sy --dbpath “$CHECKUPDATES_DB” --logfile /dev/null &> /dev/null; then
error ‘Cannot fetch updates’
exit 1
fi
mapfile -t updates < <(pacman -Qu --dbpath “$CHECKUPDATES_DB” 2> /dev/null | grep -v ‘[.*]’)
if (( ${#updates[@]} )); then
printf ‘%s\n’ “${updates[@]}”
if (( DOWNLOAD_CACHE )); then
sudo pacman -Sw --noconfirm “${updates[@]%% *}” --dbpath “$CHECKUPDATES_DB” --logfile /dev/null
fi
else
exit 2
fi
vim: set noet:
[pebcak@eos-cinnamon ~]$ cat /usr/bin/checkupdates | grep pacman.conf
