greetings fellow users, ill cut right to the chase
i am trying to get a usb to hdmi adapter working on my lenovo laptop.
The adapter is a Gana model number: AB-DE-USB2HDMI.
After a bit of searchign i was led to https://wiki.archlinux.org/title/DisplayLink
and as one might guess, the arch wiki was not successful, upon creating the formerly mentioned file, my “xrandr --listproviders” has not changed.
Does anybody else have a guess what might be the problem? or is it just not going to work at all?
Sidenote: the adapter is recognized, plugging it in its recognized with a small 8mb “cd” partition with 2 exe files in it.
Someone might have some pointers, but I wouldn’t hold out hope. DisplayLink under Linux is patchy in general (given it’s a proprietary protocol), and after reading some Amazon reviews this particular adapter doesn’t even seem to work under Windows…
According to what i read it supports. Mirror and extended mode: the USB to HDMI converter has 2 modes. Mirror mode displays the same images, giving you a better visual experience. Advanced Mode expands your workspace by up to two additional monitors, a TV or projector via the USB interface. The tow files inside the folder are drivers for Windows xp and Win7 to 10. I would make sure it’s plugged into usb 3.0 port.
I don’t know much about display-link other then what i read.
Did you run this as you said plugging in is recognized as a usb device but?
it has been recognized before as well,with the small 8mb partition
i tried both the usb 3 and 2 port, neither makes a difference as far as i caa tell (the laptop has 2 usb 3 ports and one 2 port)
You may need to use evdi for displaylink i really don’t know much about it. evdi is a kernel module for displaylink. This is really getting into unknown territory so i can’t really help. But here is a link. I just don’t want you to mess up your whole system. Is this usb adapter a displaylink?
It might be that you’re just out of luck on this one. The very first two lines on the Arch wiki page say:
DisplayLink devices on Linux still only have experimental support. While some people have had success in using them, it is generally not an easy process and not guaranteed to work.
while it likely just wont work, it does seem i have missed step 4
" For Xorg use the “modesetting” driver with AccelMethod “none” and MatchDriver “evdi”.
and as many times with the arch wiki, i have no idea what it wants from me here
Can you somehow test it on a windows machine first (since it’s designed to work with Windows, given the two exe files) to make sure the adapter actually works at all?
