USB Port problem
When I’m booting my system i get this warning recently:
usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
I don’t know exactly since when this message shows up. I only have a keyboard and an USB hub connected to the PC.
You might try disconnecting one of those during boot, and see if the warning goes away?
If it goes away, you at least know the culprit.
Sorry for the late response. It was an USB-C Hub. Disconnect and reconnect it and everything works without errors :slight_smile:
