Tittle pretty much says it all
I’m running Endeavour OS on the Linux Zen kernel, KDE window manager,
there’s my Pulse audio config,
Razer kraken is the headset, and it has been detected before… As you can see I have the system set to automatically switch to it when I plug it in.
99% of the time I plug it in ,and it’s not detected though. Even if I go to devices, and try to switch manually it just isn’t listed there.
ok here we go
Started with them plugged i
unplugged, then re-plugged while command was running
[james@James-EOS ~]$ journalctl -f
-- Logs begin at Tue 2020-07-28 22:38:14 EDT. --
Aug 02 06:05:50 James-EOS kwin_x11[1022]: file:///usr/share/kwin/aurorae/MenuButton.qml:22: TypeError: Cannot read property 'closeOnDoubleClickOnMenu' of null
Aug 02 06:05:50 James-EOS kwin_x11[1022]: QPainter::begin: Paint device returned engine == 0, type: 3
Aug 02 06:05:56 James-EOS org_kde_powerdevil[1181]: powerdevil: Releasing inhibition with cookie 1040
Aug 02 06:05:56 James-EOS org_kde_powerdevil[1181]: powerdevil: Restoring DPMS features after inhibition release
Aug 02 06:05:56 James-EOS org_kde_powerdevil[1181]: powerdevil: Scheduling inhibition from ":1.17" "My SDL application" with cookie 1041 and reason "Playing a game"
Aug 02 06:05:56 James-EOS org_kde_powerdevil[1181]: powerdevil: Can't contact ck
Aug 02 06:05:58 James-EOS packagekitd[217496]: pk_alpm_transaction_dlcb: assertion 'complete <= total' failed
Aug 02 06:05:58 James-EOS PackageKit[217496]: get-updates transaction /8_eadaccbd from uid 1000 finished with success after 1668ms
Aug 02 06:05:58 James-EOS dbus-daemon[685]: [system] Activating via systemd: service name='org.freedesktop.locale1' unit='dbus-org.freedesktop.locale1.service' requested by ':1.24403' (uid=1000 pid=116554 comm="/usr/bin/gnome-software ")
Aug 02 06:05:58 James-EOS audit: BPF prog-id=42 op=LOAD
Aug 02 06:05:58 James-EOS kernel: audit: type=1334 audit(1596362758.965:232): prog-id=42 op=LOAD
Aug 02 06:05:58 James-EOS kernel: audit: type=1334 audit(1596362758.965:233): prog-id=43 op=LOAD
Aug 02 06:05:58 James-EOS audit: BPF prog-id=43 op=LOAD
Aug 02 06:05:58 James-EOS systemd[1]: Starting Locale Service...
Aug 02 06:05:59 James-EOS dbus-daemon[685]: [system] Successfully activated service 'org.freedesktop.locale1'
Aug 02 06:05:59 James-EOS systemd[1]: Started Locale Service.
Aug 02 06:05:59 James-EOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 06:05:59 James-EOS kernel: audit: type=1130 audit(1596362759.196:234): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-localed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Aug 02 06:05:59 James-EOS PackageKit[217496]: resolve transaction /9_daeebcab from uid 1000 finished with success after 0ms
Aug 02 06:05:59 James-EOS PackageKit[217496]: get-details transaction /10_abbceacc from uid 1000 finished with success after 0ms
Aug 02 06:06:00 James-EOS packagekitd[217496]: pk_alpm_transaction_dlcb: assertion 'complete <= total' failed
Aug 02 06:06:00 James-EOS PackageKit[217496]: get-updates transaction /11_bcdeebda from uid 1000 finished with success after 589ms
Aug 02 06:06:00 James-EOS PackageKit[217496]: get-details transaction /12_bcbcbece from uid 1000 finished with success after 0ms
Aug 02 06:06:01 James-EOS org_kde_powerdevil[1181]: powerdevil: Enforcing inhibition from ":1.17" "My SDL application" with cookie 1041 and reason "Playing a game"
Aug 02 06:06:01 James-EOS org_kde_powerdevil[1181]: powerdevil: Added change screen settings
Aug 02 06:06:01 James-EOS org_kde_powerdevil[1181]: powerdevil: Added interrupt session
Aug 02 06:06:01 James-EOS org_kde_powerdevil[1181]: powerdevil: Disabling DPMS due to inhibition
Aug 02 06:06:01 James-EOS org_kde_powerdevil[1181]: powerdevil: Can't contact ck
Aug 02 06:06:08 James-EOS kernel: usb 1-2: USB disconnect, device number 14
Aug 02 06:06:15 James-EOS kernel: usb 1-2: new full-speed USB device number 15 using xhci_hcd
Aug 02 06:06:15 James-EOS kernel: usb 1-2: New USB device found, idVendor=1532, idProduct=0510, bcdDevice=67.02
Aug 02 06:06:15 James-EOS kernel: usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Aug 02 06:06:15 James-EOS kernel: usb 1-2: Product: Razer Kraken 7.1 V2
Aug 02 06:06:15 James-EOS kernel: usb 1-2: Manufacturer: Razer
Aug 02 06:06:15 James-EOS kernel: usb 1-2: SerialNumber: 00000000
Aug 02 06:06:16 James-EOS kernel: input: Razer Razer Kraken 7.1 V2 Consumer Control as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.1/usb1/1-2/1-2:1.3/0003:1532:0510.0014/input/input53
Aug 02 06:06:16 James-EOS kernel: input: Razer Razer Kraken 7.1 V2 as /devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.1/usb1/1-2/1-2:1.3/0003:1532:0510.0014/input/input54
Aug 02 06:06:16 James-EOS kernel: hid-generic 0003:1532:0510.0014: input,hiddev3,hidraw9: USB HID v1.11 Device [Razer Razer Kraken 7.1 V2] on usb-0000:05:00.1-2/input3
Aug 02 06:06:16 James-EOS mtp-probe[219003]: checking bus 1, device 15: "/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.1/usb1/1-2"
Aug 02 06:06:16 James-EOS mtp-probe[219003]: bus: 1, device: 15 was not an MTP device
Aug 02 06:06:16 James-EOS systemd-udevd[219033]: controlC3: Process '/usr/bin/alsactl restore 3' failed with exit code 99.
Aug 02 06:06:16 James-EOS mtp-probe[219047]: checking bus 1, device 15: "/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.0/0000:03:08.0/0000:05:00.1/usb1/1-2"
Aug 02 06:06:16 James-EOS mtp-probe[219047]: bus: 1, device: 15 was not an MTP device
Hello @Lancaban
I don’t know if this would help but there are some packages in the AUR called openrazer. There is a github page you can read some stuff. Not sure if it helps.
openrazer-meta
openrazer-driver-dkms
openrazer-daemon
Still having this issue, still no progress, anyone with any ideas please let me know
Lancaban:
Razer kraken
Did you add the following to /etc/pulse/default.pa
load-module module-switch-on-connect
I thought I had accomplished this by using the checkbox in the audio settings GUI, but I’m not seeing it in the file. I’ll add it manually and see if that helps
Sadly no luck
I still have to plug & unplug several times to get it to work
I hear the headphones like “click” when they get plugged in, but they aren’t showing up in the list of audio devices at all. I have tried them in a different system to ensure it’s not a loose wire or something in the headphones themselves, and they work flawlessly.
I’m completely stumped
No particular expertise here - but have you varied which USB port you plug it into? I’ve been having fun with KVM switching, and which type of USB port seems to matter a LOT…
Yes I have tried several ports
Pass-through on my keyboard, Front port on Case, and direct on the back of the Motherboard.
