USB-C Headphones not detected
Hi guys
My headphones does not work with USB type C
I get a system info, that device is tagged as keyboard :expressionless: . What to do?
mar 25 18:40:07 zen mtp-probe[11943]: bus: 1, device: 12 was not an MTP device
mar 25 18:40:07 zen /usr/lib/gdm-x-session[1173]: (II) event21 - ESS Technology Asus USB DAC: is tagged by udev as: Keyboard
mar 25 18:40:07 zen /usr/lib/gdm-x-session[1173]: (II) event21 - ESS Technology Asus USB DAC: device is a keyboard
mar 25 18:40:07 zen /usr/lib/gdm-x-session[11942]: thunar-volman: Unsupported input device type "(null)".
mar 25 18:40:07 zen /usr/lib/gdm-x-session[11950]: thunar-volman: Unsupported input device type "/dev/input/event21".
mar 25 18:40:08 zen /usr/lib/gdm-x-session[11955]: thunar-volman: Unsupported USB device type "usbhid".
mar 25 18:40:08 zen /usr/lib/gdm-x-session[11960]: thunar-volman: Unsupported USB device type "snd-usb-audio".
mar 25 18:40:08 zen /usr/lib/gdm-x-session[11965]: thunar-volman: Unsupported USB device type "snd-usb-audio".
mar 25 18:40:14 zen wpa_supplicant[698]: wlan0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-59 noise=9999 txrate=12150
extra info:
inxi -Aa
  Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 1-1:6 chip-ID: 0495:3042 pcie:
    class-ID: 0300 gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
    driver: snd_rn_pci_acp3x v: kernel
    alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
    class-ID: 0403
  Device-4: ESS Asus USB DAC type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Sound API: ALSA v: k6.2.7-arch1-1 running: yes
  Sound Server-2: PipeWire v: 0.3.67 running: yes
CPU: 6-core AMD Ryzen 5 5500U with Radeon Graphics (-MT MCP-)
speed/min/max: 1495/1400/4056 MHz Kernel: 6.2.7-arch1-1 x86_64 Up: 4h 12m
Mem: 7370.7/15372.9 MiB (47.9%) Storage: 491.45 GiB (10.1% used) Procs: 356
Shell: Bash inxi: 3.3.25
Can’t say I know for sure maybe pulseaudio is conflicting with pipewire. . . they’re both running and you only need one of these for your audio to work. I’m sure that’s the issue I’ve had in the past. Get rid of pulse audio . . . I think pipewire is all you need. . . I could be wrong though. . . . you can always reinstall the package you remove. Try that for starters.
Rich;)
Hi rich52
It says that only PipeWire is running
Anyways, this is the only one issue I have with EoS but annoying.
See if your wireless headphones are disconnected in pulseaudio. . . if they are connect them and then see if everything works. . . .I’ve got an old pair of Logitech wireless headphones and I think I’ve had to mess around with settings in both. . . I could be wrong once again. My headphones do work but I have to activate them once they are on by pushing a button on the side until I get a squack from them indicating that they are communicating with the sensor in my USB port.
Rich :wink:
May I ask you if you’re using a 6+ kernel?
Briefly: I’ve faced a very similar problem with HDMI audio since kernel 6x:
Not really solved it yet, but found a workaround using linux-rt-lts kernel, which is still a ‘5.15.96.61’:
sudo pacman -S linux-rt-lts linux-rt-lts-headers
Ref:
My educated guess for now is ‘blame it on kernel 6*’.
Hope this can help,
Piero
Hi, yes - it’s 6.2.7. Thanks for links - I will check
                   ./sssso-                -----------
                 `:osssssss+-              OS: EndeavourOS Linux x86_64
               `:+sssssssssso/.            Host: ZenBook UX425UA_UM425UA 1.0
             `-/ossssssssssssso/.          Kernel: 6.2.7-arch1-1
           `-/+sssssssssssssssso+:`        Uptime: 5 mins
         `-:/+sssssssssssssssssso+/.       Packages: 1063 (pacman)
       `.://osssssssssssssssssssso++-      Shell: bash 5.1.16
      .://+ssssssssssssssssssssssso++:     Resolution: 3840x2160, 1920x1080
    .:///ossssssssssssssssssssssssso++:    DE: Xfce 4.18
  `:////ssssssssssssssssssssssssssso+++.   WM: Xfwm4
`-////+ssssssssssssssssssssssssssso++++-   WM Theme: WhiteSur-Dark
 `..-+oosssssssssssssssssssssssso+++++/`   Theme: Yaru-Purple-dark [GTK2], Arc-Darker [GTK3]
   ./++++++++++++++++++++++++++++++/:.     Icons: Flatery-Dark [GTK2], Qogir [GTK3]
  `:::::::::::::::::::::::::------``       Terminal: xfce4-terminal
                                           Terminal Font: Source Code Pro Medium 13
                                           CPU: AMD Ryzen 5 5500U with Radeon Graphics (12) @ 2.100GHz
                                           GPU: AMD ATI 04:00.0 Lucienne
                                           Memory: 3494MiB / 15372MiB
Hi, with 6.2.9 kernel version, headphones are detected corrrectly.
❯ inxi -Aa
    driver: snd_hda_intel v: kernel bus-ID: 1-1:4 chip-ID: 0495:3042 pcie:
    gen: 3 class-ID: 0300 speed: 8 GT/s lanes: 16 link-max: gen: 4
    driver: snd_rn_pci_acp3x v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
    link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2
    class-ID: 0480
    class-ID: 0403
  API: ALSA v: k6.2.9-arch1-1 status: kernel-api tools: alsamixer,amixer
  Server-1: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
