USB Audio inputs stopped working
Both using pipewire and pulseaudio, My USB headphones do not emit sound (Apart from noise static, which has always been there).
Issue started on pipewire, and I just tried to switch entirely to pulseaudio, I still get the problem.
I have no idea what could be happening here, I don’t even remember when it stopped working.
In pavucontrol, my usb headset shows up, However even if I playback sound there, the volume meter doesn’t change, unless I change the configuration to digital audio (from analog), I don’t even know what that would change, however safe to say it still doesnt work.
This issue doesn’t occur on other computers, with the same usb connections, including the same PC running EndeavourOS with the boot usb drive.
