I just installed endeavoros, everything looks good. But I my external hdd is not detected with USB 3.0 port, while using USB 2.0 port no problem occurred.
My external hdd is using ntfs. I tried plug my USB flashdrive (exfat) with USB 3.0 port, and it’s working perfectly.
I hope anyone in this forum can solved my problem.
When you say it happens so often what do you mean? If you boot it and it’s detected as you say that means it can see the device. Then you can mount it or it is already mounted. There is a difference between the device being seen or recognized and being mounted so you can access it? So when you say it happens so often does the device disappear? Or you can’t mount it?
Edit: If the device is disappearing after a while i would suspect it is power management of the usb?
auto-suspend
