i get this when i try to upgrade:
Summary
[fj@whitewolf ~]$ sudo pacman -Syu
[sudo] password for fj:
endeavouros 34.3 KiB 6.55 KiB/s 00:05 [--------------------------------] 100%
core is up to date
extra 1736.3 KiB 201 KiB/s 00:09 [---------------------------------------------------------------------------------------] 100%
community 7.1 MiB 649 KiB/s 00:11 [--------------------------------] 100% 3.0 MiB 1475 KiB/s 00:02 [-----------------------------------co o o o o o o :: Starting full system upgrade...1%
resolving dependencies... 168.7 KiB 25.6 KiB/s 00:07 [-----------------------------looking for conflicting packages...
:: installing evolution-data-server (3.46.1-2) breaks dependency 'libcamel-1.2.so=63-64' required by pantheon-mail
:: installing evolution-data-server (3.46.1-2) breaks dependency 'libedataserver-1.2.so=26-64' required by pantheon-mail
:: installing evolution-data-server (3.46.1-2) breaks dependency 'libedataserverui-1.2.so=3-64' required by pantheon-mail
:: installing evolution-data-server (3.46.1-2) breaks dependency 'libecal-2.0.so=1-64' required by pantheon-tasks
:: installing evolution-data-server (3.46.1-2) breaks dependency 'libedataserver-1.2.so=26-64' required by pantheon-tasks
:: installing evolution-data-server (3.46.1-2) breaks dependency 'libcamel-1.2.so=63-64' required by switchboard-plug-online-accounts
:: installing evolution-data-server (3.46.1-2) breaks dependency 'libedataserver-1.2.so=26-64' required by switchboard-plug-online-accounts
[fj@whitewolf ~]$
Apparently, evolution and Pantheon mail do conflict with each other, so I think you have to make a choice about which one you want to use.
dalto
November 2, 2022, 12:49pm
3
It looks like pantheon-mail
was dropped from the repos. Since it is now locked in time, you probably need to remove it, complete your update and then wait for someone to add it to AUR or build it yourself against current libraries.
i removed it and now i get this:
Summary
:: installing evolution-data-server (3.46.1-2) breaks dependency ‘libecal-2.0.so=1-64’ required by pantheon-tasks
:: installing evolution-data-server (3.46.1-2) breaks dependency ‘libedataserver-1.2.so=26-64’ required by pantheon-tasks
:: installing evolution-data-server (3.46.1-2) breaks dependency ‘libcamel-1.2.so=63-64’ required by switchboard-plug-online-accounts
:: installing evolution-data-server (3.46.1-2) breaks dependency ‘libedataserver-1.2.so=26-64’ required by switchboard-plug-online-accounts
[fj@whitewolf ~]$ sudo pacman -Rns pantheon-mail
error: target not found: pantheon-mail
[fj@whitewolf ~]$
i apologize i removed pantheon-mail because i don’t use it. it is still having a problem but i do believed BOTH of you helped.
dalto
November 2, 2022, 12:54pm
5
Remove pantheon-tasks
and then remove orphans.
thankx that was what i was thinking but i wanted to make sure… i shall do this now. thanks again for your help.
dalto:
pantheon-tasks
i had to remove online accounts as well which sucks because i liked that feature in pantheon but you gotta do what you gotta do. there is probably a reason i need to get ride of it in order to upgrade so i did. thanks again i think i would not have been able to figure this out without you.
dalto
November 2, 2022, 12:58pm
8
If that is in AUR now you can probably reinstall it. It just would need to be built against current libraries.
You can try to install online accounts after…
Never mind, @dalto beat me to it.
system
Closed
November 4, 2022, 1:00pm
10
