Updating endeavouros-theming requires manual intervention
If you encounter an error while updating due to this package manual intervention is required… :hugs:
Please issue the following commands and answer yes to both.
First:
sudo pacman -Sy endeavouros-theming --overwrite /etc/pacman.d/hooks/\*
Then:
sudo pacman -Syu
Thank you @dalto :yum:
related topic
you went modo Elloquin
Is that good or bad… :sweat_smile:
