Is this disaster with grub the only reason why the EOS developers turned to systemd-boot?
No
and �
Some of the advantages of systemd-boot have been mentioned in this article if you would like to learn more about it:
https://discovery.endeavouros.com/installation/systemd-boot/
One thing i find with systemd-boot is the resolution isnât as easy to set as it is in grub when itâs booting before the desktop.
Edit: I find it easier to set in grub and it works the way i want to see it.
Not saying I donât like systemd-boot. Just donât have much experience with it.
In loader.conf
you can specify a console-mode
line, which can be set to any of these values:
0
Standard UEFI 80x25 mode1
80x50 mode, not supported by all devices2
the first non-standard mode provided by the device firmware, if anyauto
Pick a suitable mode automatically using heuristicsmax
Pick the highest-numbered available modekeep
Keep the mode selected by firmware
I believe keep
is the default, but if that looks a bit low-res you could try setting it to max
like so:
console-mode max
Yes i know you can do this but it doesnât match what you can set using grub. I use 1920x1080 which is the same resolution as my monitor on grub.
Edit: At least i donât know how to get it to set 1920x1080
That works, thanks @BluishHumility. I would use systemd-boot, but I like the access to snapper snapshots and as far as I know there is still no way to do it with systemd-boot. I do know systemd-boot does make multi-distro installs a lot easier and less of a headache. I can now use my portable usb-arch install and it wont mess up my laptop which uses systemd.
grub-install --no-nvram
as mentioned by @dalto might cover most cases.
But there may be other cases where additional parameters would be needed.
One that comes to my mind, if I am not mistaken, is when the user have ESP mounted at /efi or /boot and not at /boot/efi which I believe to be the default path for grub-install. In those cases--efi-directory=
will be needed. Ex: efi-directory=/efi
Also, some implementations of UEFI:s wonât read the default path to the bootloader file grubx86.efi and use the fallback path to /esp/EFI/BOOT/BOOTX86.efi (esp being ESPâs mount point). In this case --removable
needs to be passed to grub-install.
There might be other cases as well I am not aware of.
If I am mistaken on any part of the above, I would appreciate correction from you @all.
Iâm one of the cases where it doesnât work grub-install --no-vram
[ehudd@endeavour ~]$ LANG=C grub-install --no-nvram
Installing for x86_64-efi platform.
grub-install: warning: disk does not exist, so falling back to partition device /dev/sdb1.
grub-install: error: disk `hostdisk//dev/sdb1' not found.
Since this was not meant to be a help but sort of a #important-notifications thread (and marked as solved on top of that ), I would suggest you to open a new thread for your grub-install issue to get adequate assistance.
Tip : You can look back at the installation commands :
sudo cat /var/log/endeavour-install.log | grep grub
The other issue is i wonder if some users are installed with Bios. What does the command do in that case if using --no-vram? Does it just ignore that anyway?
If you are installed with BIOS you shouldnât use the command identified as âfor UEFIâ
I understand that. I just wondered if users reading here understand that and if they used the command on a Bios install what happens?
Edit: Does the command grub-install work on Bios also?
Oh! Sorry. Iâll do that.
No idea. It will either return an error or succeed. However, it shouldnât hurt anything.
Yes but I am havenât tested what specific flags you need to update an existing grub install.
Wasnât it only the UEFI systems hit by the Grub issue back then when it started?
So, is it then recommended for Legacy systems to do a grub-install when Grub package is updated?
Yes, but that was because that specific change was related to UEFI
I would think so. If you donât run grub-install, you are only getting part of the update. The core image wonât be updated. Relatively speaking, the risk is probably lower than with UEFI but I would still consider doing it.
For Bios/Legacy installations:
The target=
part can be skipped, so it is just sudo grub-install /<drivename>
evermore, as it seems to me, who is on âLegacy/Bios-â installations all the time.
It is not only my machines getting old, but me too.
