Update-grub failed. someone help please
There it is, your failure.
Smartie!
And you hate systemd because of the bloat? :rofl:
I have it set up in a virtual box to run the Tamriel Trade Center client for eso but I couldn’t get it to run under wine.
I encountered the same problem of not being able to run the command “#update-grub”
So, I created the command following the instructions below and it works!
bash: update-grub: command not found
So I manually created one as below:
sudo nano /usr/sbin/update-grub
This will create a new empty file.
Type the following in the empty file:
#!/bin/sh
set -e
exec grub-mkconfig -o /boot/grub/grub.cfg “$@”
save the file and exit.
Then I ran in the terminal:
sudo chown root:root /usr/sbin/update-grub
sudo chmod 755 /usr/sbin/update-grub
This way I manually created an update-grub command just like many other distributions. Then I ran:
sudo update-grub
This is not how you update grub on an Arch based system. Those are ubuntu based commands!
Edit: Please use the following.
Edit2: Please refer to the Arch Wiki
https://wiki.archlinux.org/title/GRUB
Edit: Sorry i misunderstood your post at first as i skimmed only the first few lines. I see what you did after realizing you couldn’t use sudo update-grub. :wink:
Pssst…
AUR (en) - update-grub (archlinux.org)
welcome on the forum @diyako indeed creating the script manually will work in the same way … you could also use an alias in your terminalRC or use the script by installing from AUR:
yay -S update-grub
aur/update-grub 0.0.1-7 (+93 2.48)
    Simple wrapper around grub-mkconfig
In addition, keep in mind to not post in year old posts… it will get lost and it is always recommended to open a new post instead.
:wink:
I didn’t know that even existed. :thinking:
What is the set -e to make it executable? I thought the exec does that? I’m bash illiterate! :sweat_smile:
:eyeglasses: set --help
:slightly_smiling_face:
I don’t RTFM. :sunglasses:
Edit: Okay…
-e Exit immediately if a command exits with a non-zero status.
