Hi,
I started using EndeavourOS about 2 months and I got an issue that I tried to resolve but can’t resolve.
I got unstable bluetooth, when I connect my headphone it crash.
What happen exactly : What ever Im doing, after 5-30 minutes, my sound cut but the bluetooth connection is still marked as “Connected”. It’s only after 10 seconds that the bluetooth connection is stopped and restarted over and over again.
I tried to see if the headphone was the problem on another computer and it works without any problem.
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 2: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
please post the results of
inxi -Faz
Kernel: 6.18.7-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc avail: acpi_pm
parameters: initrd=\96f0cd8e47424a079bb7e1c8d4eeaedd\6.18.7-arch1-1\initrd
nvme_load=YES nowatchdog rw
root=UUID=c67d7424-7bdd-4380-a62d-97d3be5df317
systemd.machine_id=96f0cd8e47424a079bb7e1c8d4eeaedd
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
Type: Desktop System: HP product: OMEN by HP 45L Gaming Desktop GT22-0xxx
v: N/A serial: <superuser required> Chassis: type: 3
Mobo: HP model: 8917 v: 00 serial: <superuser required>
part-nu: 65G15EA#UUZ uuid: <superuser required> Firmware: UEFI vendor: AMI
v: F.51 date: 11/02/2023
Info: model: 12th Gen Intel Core i7-12700K bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x97 (151) stepping: 2
microcode: 0x3D
Topology: cpus: 1x dies: 1 clusters: 9 cores: 12 threads: 20 mt: 8 tpc: 2
st: 4 smt: enabled cache: L1: 1024 KiB desc: d-4x32 KiB, 8x48 KiB; i-8x32
KiB, 4x64 KiB L2: 12 MiB desc: 8x1.2 MiB, 1x2 MiB L3: 25 MiB
desc: 1x25 MiB
Speed (MHz): avg: 829 min/max: 800/5000:3800 scaling: driver: intel_pstate
governor: powersave cores: 1: 829 2: 829 3: 829 4: 829 5: 829 6: 829 7: 829
8: 829 9: 829 10: 829 11: 829 12: 829 13: 829 14: 829 15: 829 16: 829
17: 829 18: 829 19: 829 20: 829 bogomips: 144383
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: gather_data_sampling status: Not affected
Type: ghostwrite status: Not affected
Type: indirect_target_selection status: Not affected
Type: old_microcode status: Not affected
Type: reg_file_data_sampling mitigation: Clear Register File
Type: spec_rstack_overflow status: Not affected
prctl
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Type: tsa status: Not affected
Type: vmscape mitigation: IBPB before exit to userspace
Device-1: NVIDIA GA104 [GeForce RTX 3070 Ti] vendor: Hewlett-Packard
driver: nvidia v: 590.48.01 alternate: nouveau,nvidia_drm
non-free: 550-580.xx+ status: current (as of 2025-11; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2
empty: DP-1,DP-3,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2482
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nv_platform,nvidia,nvidia-nvswitch
display-ID: 0
Monitor-1: DP-2 model: Dell U4919DW serial: <filter> built: 2019 res:
mode: 5120x1440 hz: 60 scale: 100% (1) dpi: 81 gamma: 1.2
size: 1198x337mm (47.17x13.27") diag: 1244mm (49") modes: max: 3840x1080
min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
x11: drv: nvidia inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB display-ID: :1.0
API: Vulkan v: 1.4.335 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 590.48.01 device-ID: 10de:2482
surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Alder Lake-S HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0401
Device-2: NVIDIA GA104 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-3: Fifine Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3
chip-ID: 3142:5060 class-ID: 0300
API: ALSA v: k6.18.7-arch1-1 status: kernel-api
Server-1: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Intel Alder Lake-S PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
Device-2: Aquantia AQtion AQC113 NBase-T/IEEE 802.3an Ethernet [Antigua
10G] vendor: ASUSTeK driver: atlantic v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 4 port: N/A bus-ID: 03:00.0 chip-ID: 1d6a:04c0
class-ID: 0200 temp: 65.0 C
IF: enp3s0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-3: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:9 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 4 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c0104
Local Storage: total: 3.19 TiB used: 1.06 TiB (33.2%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital model: PC SN530
SDBPNPZ-512G-1006 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
fw-rev: HPS2 temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 53.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04UBD200
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> fw-rev: 5438 scheme: MBR
ID-1: / raw-size: 474.94 GiB size: 466.41 GiB (98.20%)
used: 17.76 GiB (3.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:4
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (rpm): cpu: 0 fan-2: 0
Memory: total: 32 GiB note: est. available: 31.09 GiB
used: 14.04 GiB (45.1%)
Processes: 487 Power: uptime: 1h 58m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
tool: systemctl
Packages: 1140 pm: pacman pkgs: 1132 libs: 322 tools: yay pm: flatpak
pkgs: 8 Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: konsole
inxi: 3.3.40
thefrog
February 4, 2026, 10:46am
4
you should check and see if there is an update for your bios
I have updated my BIOS from F.51 to F57 (latest available) but now I can’t even connect my headphone in bluetooth.
Feb 05 19:31:11 unrecon-desktop bluetoothd\[6587\]: **src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down**
Feb 05 19:31:11 unrecon-desktop bluetoothd\[6587\]: **Failed to set mode: Busy (0x0a)**
Feb 05 19:31:14 unrecon-desktop bluetoothd\[6587\]: **src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to 58:18:62:3D:72:C8: Permission denied (13)**
I had some BT issues at work on a Lenovo laptop with an Intel AX210 WIFI adapter, I think it is? It’s a combo WIFI/BT wireless adapter in a laptop.
I used this URL to get enough tips to resolve the issue: now everything connects fine for me–my mouse and JBL earbuds and a BlasterX gaming headset.
HOWEVER: the laptop is Linux certified so the drivers are all there. I am unsure about your device but you might want to take a look at what helped me:
EDIT: obviously the Ubuntu specific stuff won’t work for you on Endeavour OS, but I HAD to say it.
Are you using Gnome? If so, there is a known problem I documented a while back: Crash with Bluetooth headphones after Wireplumber 5.13-1 update
If this is the case, you will need to downgrade wireplumber & libwireplumber until a fix is worked out.
Hmmm…I see you are on KDE, but you might still do a downgrade to see if that “fixes” your problem.
I see your issue involves the same handoff problem. Follow the links in my post to see what is going on.
Hi,
thanks for the documentation, it seems that it has solved the problem.
Im gonna try fully tomorrow and be sure that it not crash but I think you solved it. Thank you!
No problem….I’ve been seeing that quite a bit after the update….I’m following the “fix” & will update the original post when there is more info.
Seems that it doesn’t fix the bluetooth
I found this in the dmesg :
[ 3324.013612] Bluetooth: hci0: Opcode 0x0401 failed: -110
[ 3324.013622] Bluetooth: hci0: command 0x0401 tx timeout
[ 3324.013633] Bluetooth: hci0: Initiating acpi reset method
[ 3326.381526] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[ 3798.050515] Bluetooth: hci0: Opcode 0x0401 failed: -125
[ 3798.051495] Bluetooth: hci0: unexpected event for opcode 0x0401
and for the bluetooth journalctl :
Feb 07 12:17:13 unrecon-desktop bluetoothd[993]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Feb 07 12:17:59 unrecon-desktop bluetoothd[993]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Connection timed out
Feb 07 12:17:59 unrecon-desktop bluetoothd[993]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 58:18:62:3D:72:C8: Connection reset by peer (104)
Feb 07 12:18:44 unrecon-desktop bluetoothd[993]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Connection timed out
Feb 07 12:18:44 unrecon-desktop bluetoothd[993]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 58:18:62:3D:72:C8: Connection reset by peer (104)
OK…I did a Google Search on: bluetoothd[993]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
And got several hits…..Bummer that the downgrade did not fix your problem…It looks like it may be harder to track down. This stood out in the search: https://github.com/arkq/bluez-alsa/issues/339
So, I tried to downgrade wireplumber, downgrade the kernel, change the configuration and change from pipewire to pulseaudio and i always get this issue.
It might be a unsolved bug from this specific config, idk.
I guess im just gonna buy a dongle and hope it works.
