Ark has 2 optional dependencies for handling the RAR format
unrar
(came installed with EOS)
unarchiver
What’s the difference? Do I only need one or the other? Can I have both installed just in case or do I risk them conflicting?
https://archlinux.org/packages/extra/x86_64/unrar/
https://archlinux.org/packages/community/x86_64/unarchiver/
Most important is that unarchiver
is Free & Open-source
You need only one.
You can have both installed, but that doesn’t make sense because they have same functionality.
One manage rar archives, the other is multiformat and support many old archives formats (Mac, DOS,Amiga) :
https://code.google.com/archive/p/theunarchiver/wikis/SupportedFormats.wiki
You can have both installed.
Balder
February 3, 2023, 7:08pm
5
Tip on the side: If you want to use unrar to unpack splitted RAR archieves, you should install libunrar in addition to unrar, otherwise the compilation will not work.
I don’t know much about it. I just use Ark on Kde.
Edit: Everything on Kde is great!
Balder
February 3, 2023, 7:27pm
7
Unrar comes preinstalled in EOS, but not libunrar, and then people wonder why they can’t unpack split RAR archives …
This thread is about ark
on KDE, specifically it’s optional dependencies.
You can install unrar-free which has less options than its proprietary counterpart.
Not needed, at least for me last year, with a 4 parts archive, libunrar is only required for Calibre (.cbr comics) and optional for doublecmd.
Balder
February 4, 2023, 12:16pm
11
weird
Update: You are right, by now unpacking and reassembling splitted archieves actually works without libunrar.
