šŸŽØ UncleSpellbinder's EOS Wallpapers
I also check DeviantArt. Though some wallpapers are under creative license. There are some that aren’t, though.
https://www.deviantart.com/search?q=wallpaper
What does creative license mean, I’m guess something like that I can use it as a wallpaper but I can’t use it and than share it as mine or something like that? Can we use them as wallpapers for screenshots and then share them on forums?
Usually refers to commercial use. Either the original creator must be credited somehow, or you must get specific permission to use it for commercial use. Personal use as a desktop background and sharing would be just fine, I’d assume.
NEW ONE
SAMPLE:
Get it HERE in full 4K resolution ( 3840x2160.png):
Really nice! :+1:
Thanks!
This one is awesome. Love seeing your work.
Thanks, @smokey! :enos_flag:
NEW ONE
SAMPLE:
  • EndeavourOS ARM Variation Here
NEW ONE
SAMPLE:
NEW ONE
SAMPLE:
FOR THOSE INTERESTED…
  • Just a quick run-through on my wallpaper creation for EndeavourOS. While each wallpaper has it’s own process, this is just an example of some of the steps used to create this specific image. The video is in 4K and best viewed full screen or on YouTube.
NEW ONE
  • Thanks to @smokey for the idea of using a realistic Sun!
SAMPLE:
Looks brilliant mate
Thank you!
NEW ONE
SAMPLE:
NEW ONE
SAMPLE:
NEW ONE
  • Specifically for KDE Plasma users
SAMPLE:
blending of the two brands is artistic and creative. keep dialing in the colors. one purple dot disappearing and the orange is iffy but the concept is brilliant.
Thanks! I was using the colors of the EOS logo. The purple one blending a bit with the planet was a choice. Appreciate the input!
ah I get it. I see it when it’s blown up now.
