Unable to locate specific package names using pacman
Howdy! Maybe someone can help me with this situation… Feeling a little blind
I’ve been trying to install packages that are listed on the AUR (https://aur.archlinux.org/), however many of the specific items I’ve been looking for aren’t being located by pacman for some reason.
I’ve searched for these items:
j4-dmenu-desktop
vscodium
code-git
chromium-snapshot-bin
But nothing seems to come up. Other packages, such as i3, nodejs and others come up just fine.
I’ve tried forcing a repository update with “pacman -Syy” as well, but no luck.
Is anyone else having this issue? Would it happen to be common? :stuck_out_tongue:
It is extremely common. It effects everyone.
pacman is only for repo packages. It doesn’t search for or install packages from the AUR. :wink:
Instead, use yay, it uses the same syntax as pacman but works with both the repos and AUR.
Dude, you’re my hero, thank you XD
I come from the land of debian so this is good info to know :tada:
Also…welcome to the forum!
Thanks! Pleasure to be here
Welcome aboard! :rocket:
:enos: :partying_face:
You can also use Bauh package manager, which does search installed and uninstalled packages from AUR.
Thanks! I’ll have a look at that as well
I advocate ‘paru’ as a unified installer.
Welcome to the forum @themThingamajig :partying_face: :tada: :balloon:
Happy learning Arch. KISS …
