Unable to create KIO worker. Can not create a socket for launching a KIO worker for protocol ‘tags’
When I right click any file from Dolphin file-manager I’m getting “Unable to create KIO worker. Can not create a socket for launching a KIO worker for protocol 'tags'.” message. I can’t even drag and drop files/folders to trash. I’m on EndeavourOS KDE DE.
When Dolphin launched from terminal I’m getting errors like
kf.kio.core: KIO Connection server not listening, could not connect
kf.kio.core: couldn't create worker: "Can not create a socket for launching a KIO worker for protocol 'tags'."
kf.kio.core: ConnectionServer::listenForRemote failed: "QLocalServer::listen: Name error"
kf.kio.core: couldn't create worker: "Can not create a socket for launching a KIO worker for protocol 'thumbnail'."
kf.kio.core: couldn't create worker: "Can not create a socket for launching a KIO worker for protocol 'trash'."
System info:
  • OS: EndeavourOS x86_64
  • Kernel: Linux 6.18.48-1-lts
  • DE: KDE Plasma 6.7.4
  • WM: KWin (Wayland)
  • CPU: Intel(R) Core™ i3-4170 (4) @ 3.70 GHz
  • GPU: NVIDIA GeForce GT 710 [Discrete]
  • Dolphin: v26.08.0
  • KDE Frameworks: 6.29.0 | Qt: Using 6.11.2 and built against 6.11.1
  • Build ABI: x86_64-little_endian-lp64
Did this happen after the update of 31-08 (version 26.08.0-5.1) ?
If it is not that version, maybe a update will solve things.
I’m not sure exactly from which version the issue is happening. I’m already on latest version of Dolphin.
Does this happen with a new user?
Found this topic on the KDE forum , don’t know if you have apparmor though.
https://discuss.kde.org/t/unable-to-create-kio-worker-can-not-create-a-socket-for-launching-a-kio-worker-for-protocol-tags/49881/4
AppArmor yes. I’ve also asked KDE forum, seems like it requires some additional configuration for Dolphin. I’ll re-check.
