Hello,
Approximately one month ago I updated my system. Before the update, it was working fine. I was on kernel version 6.15.8-arch1-1.
I updated to kernel version 6.17.5-arch1-1. For whatever reason, I started having issues controlling my fans with CoolerControl. I posted a support ticket to the CoolerControl and we have concluded that:
Before the update, my system was only loading the dell_smm driver. With only this driver loaded, controlling my fans worked perfectly. After updating, alienware_smm driver started to also load. So now I have both dell_smm and alienware_smm drivers loading for the same hardware. Controlling fans no longer works.
I did not set either of them to load. I have not altered anything to cause a change in the loading of these drivers. We suspect that something changed on your side. What changed, what is the reason, and how are these modules loaded?
Thanks!
System Specs
./o. omni@omni-dellg155515
./sssso- ---------------------
`:osssssss+- OS: EndeavourOS x86_64
`:+sssssssssso/. Host: Dell G15 5515 (1.18.0)
`-/ossssssssssssso/. Kernel: Linux 6.17.5-arch1-1
`-/+sssssssssssssssso+:` Uptime: 3 days, 3 hours, 14 mins
`-:/+sssssssssssssssssso+/. Packages: 1647 (pacman), 18 (flatpak-system), 16 (flatpak-user)
`.://osssssssssssssssssssso++- Shell: zsh 5.9
.://+ssssssssssssssssssssssso++: Display (F156P1): 1920x1080 in 16", 60 Hz [External]
.:///ossssssssssssssssssssssssso++: Display (CMN1522): 1920x1080 in 16", 120 Hz [Built-in] *
`:////ssssssssssssssssssssssssssso+++. DE: KDE Plasma 6.5.0
`-////+ssssssssssssssssssssssssssso++++- WM: KWin (Wayland)
`..-+oosssssssssssssssssssssssso+++++/` WM Theme: Breeze
./++++++++++++++++++++++++++++++/:. Theme: Breeze (Dark) [Qt], Breeze-Dark [GTK2], Breeze [GTK3/4]
`:::::::::::::::::::::::::------`` Icons: breeze-dark [Qt], breeze-dark [GTK2/3/4]
Font: Noto Sans (10pt) [Qt], Noto Sans (10pt) [GTK2/3/4]
Cursor: breeze (24px)
Terminal: konsole 25.8.2
Terminal Font: JetBrainsMono Nerd Font Mono (10pt, SemiBold)
CPU: AMD Ryzen 7 5800H (16) @ 4.46 GHz
GPU 1: NVIDIA GeForce RTX 3050 Ti Mobile [Discrete]
GPU 2: AMD Radeon Vega Series / Radeon Vega Mobile Series [Integrated]
Memory: 8.86 GiB / 22.82 GiB (39%)
Swap: 24.00 KiB / 8.00 GiB (0%)
Disk (/): 43.09 GiB / 78.19 GiB (55%) - ext4
Disk (/home): 208.64 GiB / 828.21 GiB (25%) - ext4
Battery (0x4D,0x31,0x36,0x48,0x69,0x03,0x03): 100% [AC Connected]
Locale: en_US.UTF-8
