Unable to Connect to AUR
I’m not able to hit the AUR or even open the webpage. Ping gives me a 100% packet loss and curl --verbose https://aur.archlinux.org gives me the following output:
* Host aur.archlinux.org:443 was resolved.
* IPv6: <ipv6>
* IPv4: <ipv4>
*   Trying [2a01:4f9:c013:9a2d::1]:443...
* connect to 2a01:4f9:c013:9a2d::1 port 443 from fe80::d38:4d95:2b2d:604c port 44680 failed: Network is unreachable
*   Trying 46.62.192.80:443...
* connect to 46.62.192.80 port 443 from 192.168.68.65 port 49130 failed: Connection timed out
* Failed to connect to aur.archlinux.org port 443 after 136206 ms: Could not connect to server
* closing connection #0
curl: (28) Failed to connect to aur.archlinux.org port 443 after 136206 ms: Could not connect to server
I’ve tried updating the mirrors with reflector and the eos-welcome app. My network runs through pi-hole, but that doesn’t seem to be blocking it. Pi-hole is using Google DNS for upstream DNS. I can connect to aur.archlinux.org if I use a VPN or use my mobile hotspot. Not really sure what else I could try here. Any suggestions?
Welcome to the community @arkam! :enos_flag::partying_face::tada:
The AUR has been subjected to an ongoing denial of service attack over the last month or so, which means from time to time, you may have difficulty accessing it.
That said, I’m currently able to access it, and I can confirm the IP address aur.archlinux.org on my system, resolves to the same IP as yours (46.62.192.80).
It’s a little tricky to isolate whether the issue is your end, or the AUR, given that we can’t assume the AUR is 100% available. Perhaps try again tomorrow and see if it’s still an issue?
According to this site the AUR seems to be up.
Unfortunately I haven’t been able to hit it for about a week now. Not really sure if this is an issue with my ISP directly at this point. I tried changing my DNS provider, but that didn’t seem to help. I am able to resolve the the address to an IP, so I’m assuming it’s not DNS.
It doesn’t appear to be DNS, particularly if the IP it’s resolving to is 46.62.192.80, which I can confirm is working here.
There seems to be something between your system, and the AUR, tripping up the connection (sorry, that’s probably obvious). Perhaps try disabling IPv6 on your system, and try again?
@arkam
Welcome to the EndeavourOS forum. :handshake: I hope you enjoy your time here.
If you are using a VPN service, try disabling it momentarily and see if you can connect.
I just tried connecting to the AUR and it worked as expected.
Pudge
Thank you.
Funny enough, if I connect to my VPN hosted somewhere in Canada, I can connect to the AUR. If I am only connected to my network, then I cannot reach the AUR. And it’s only the AUR. I can still visit https://archlinux.org, but for some reason, not the subdomain https://aur.archlinux.org.
Would ipv6 be an issue if the network isn’t configured for using ipv6 to begin with? Not really sure how that works, if I’m honest. My ISP doesn’t support ipv6, so I just left that config disabled on my router.
This will only be for Arch and EOS mirrors. No effect on AUR.
