You are right.
After all, even a broken clock tells the right time twice a day. ![]()
Sorry but I just canāt appreciate Mint, I prefer Debian to LMDE.
You are right.
No, this is false and it sounds like you do not understand. Arch-based distros can introduce troubleshooting complexities not present in stock Arch, making it more appropriate for related issues to be raised on the distroās own support forum. https://terms.archlinux.org/docs/code-of-conduct/#arch-linux-distribution-support-only
These distributions often use different packages, package versions, repositories, or make custom system configurations silently, practically rendering support for such projects within Arch Linux impossible.
That is to say, there is no disdain for Arch-based distros; rather, the āgreat distainā is directed at the users who ignore this policy or canāt be bothered to read the CoC in the first place.
Not for nothing, but this stance you have adopted in the wake of your frustration (āEndeavour sucks because I couldnāt figure out how to set up UFW and went back to Linux Mint instead of learning how it worksā) makes you look kind of foolish.
Iām going to close this thread because it appears the need for support is behind us. If you would like to continue to share your experience about how one time you tried to set up UFW on Endeavour but gave up and switched to Linux Mint instead, maybe the Linux Mint forum has a category for that.
