Udev Rules not working
Hi ,
it seems anything I put in udev rules are not working
For example
kate /etc/udev/rules.d/60-ioschedulers.rules
# set scheduler for NVMe
ACTION==“add|change”, KERNEL==“nvme[0-9]n[0-9]”, ATTR{queue/scheduler}=“none”
# set scheduler for SSD and eMMC
ACTION==“add|change”, KERNEL==“sd[a-z]*|mmcblk[0-9]*”, ATTR{queue/rotational}==“0”, ATTR{queue/scheduler}=“mq-deadline”
# set scheduler for rotating disks
ACTION==“add|change”, KERNEL==“sd[a-z]*”, ATTR{queue/rotational}==“1”, ATTR{queue/scheduler}=“bfq”
cat /sys/block/nvme0n1/queue/scheduler
mq-deadline kyber [bfq] none
Any Idea how to fix it?
my nvme - line looks like this and is working:
# set mq-deadline scheduler for non-rotating nvme-disks
ACTION=="add|change", KERNEL=="nvme[0-9]n1", ATTR{queue/rotational}=="0", ATTR{queue/scheduler}="mq-deadline"
The problem is not with the rules but with UDEV since the rules are not triggering while the service is running
Just to eliminate the simplest possibility, have you rebooted (or reloaded udev rules with sudo udevadm trigger)?
is ok is fixed ,
The problem was that I have used copy paste and I think something went wrong in KATE but when I have used a plain text editor like gedit or nano it worked.
Below you can find my udev rules that sets read_ahead as well for faster perfomance
ACTION==“add|change”, KERNEL==“nvme[0-9]n[0-9]”, ATTR{queue/scheduler}=“none”,ATTR{bdi/read_ahead_kb}=“4096”
ACTION==“add|change”, KERNEL==“sd[a-z]|mmcblk[0-9]”, ATTR{queue/rotational}==“0”, ATTR{queue/scheduler}=“mq-deadline”,ATTR{bdi/read_ahead_kb}=“4096”
ACTION==“add|change”, KERNEL==“sd[a-z]*”, ATTR{queue/rotational}==“1”, ATTR{queue/scheduler}=“bfq”,ATTR{bdi/read_ahead_kb}=“2096”
