Two volume controls in the info area
One is the normal icon, the other is a dummy icon. Why this?
When changing the volume with the special keys of the notebook, the volume applet is displayed, but the percentages do not change. Bug? Can I fix this?
Can you share a screenshot? Do you have more than 1 DE installed?
KMix and the Plasma Volume applet have identical icons.
volume
Click and/or right click on both of them and see what they are,
Do you have more than one DE installed?
Right click on the system tray widget → configure system tray → entries
You should be able to see what it is here and disable if you like
This was the solution, i disable kmix icon from autostart and now works everything fine
You can mark the post as the solution, it will help others to find answers when searching
