Only me?
It’s not possible, the header is an additional plugin. We used a different plugin for the links in the past, but it didn’t work well on mobile devices.
EDIT
The previous one also broke often after an update of the forum software.
I use here FF 74.0,
error comes after update from FF developer
or maybe extensions are bad.
[2020-03-21T12:22:56+0100] [ALPM] upgraded firefox-noscript (11.0.15-1 -> 11.0.19-1)
[2020-03-21T12:22:56+0100] [ALPM] upgraded firefox-extension-https-everywhere (2019.11.7-1 -> 2020.3.16-1)
[2020-03-21T12:22:56+0100] [ALPM] upgraded firefox-developer-edition-i18n-de (75.0b5-1 -> 75.0b6-1)
[2020-03-21T12:22:56+0100] [ALPM] upgraded firefox-developer-edition (75.0b5-1 -> 75.0b6-1)
Edit: Opera are fine
Wait, I misinterpreted the question, I thought it was a suggestion. I will check it.
I don’t have it, it displays the same as in other browsers. Try logging out and in and otherwise deactivate all your FF plugins and start them one at the time.
My fault it was the invidio. ??? thing, I mark trust in noscript and all is fine.
I could have built it as fake but I would never do that here in the forum
@ricklinux no , it was noscript
but it is not more showing
Are you using Cinnamon desktop? Oh you figured it out?
Is noscript an extension in Firefox?
Yes upgrade today, I start first like @Bryanpwo said check the plugins and noscript is the guilty
