I am running eos with kde/kwin and i am configuring it to be much less focused on mouse usage. If i have an application open they usually have a section with like an editing field and a bar on the side with files maybe (for example obsidian, dolphin, vs code) is there a command in kwin i can configure to switch between these?
I know this is hard to describe, but for example, if i make some notes in obsidian and want to change to a note from the file tree, i don’t want to use the mouse, as i am already with my hands on my keyboard, maybe this clears it a bit up.
That would be handled from within each application.
You would need to check the key bindings for each application.
Allrighty, thank you!
