Todays update Causes GDM and gnome-shell to crash
Rollback both libxkbcommon & libxkbcommon-x11 to regain a working system
Bug report here
https://bugs.archlinux.org/task/64191
HTH
So that is was caused my system to crash, looks like they already have it patched, rebooted with the EOS ISO chrooted and did pacman -Syu and they were both updated. Also reinstalled gnome-shell and gdm for good measure. System rebooted without issue
hello, you are on archlinux testing for having this update
Yes its fixed - wow that was quick.
Looks like I chose just the wrong moment to do an update!
nope not on testing, just looks like they pushed this out pretty fast
sometimes helps waiting few days on some updates :slight_smile:
I’m treating it as good training on recovering from a broken system :wink:
I saw this update
libxkbcommon 0.9.1-1 x86_64
lib32-libxkbcommon 0.9.1-1, it works on gnome and mate
Strange, that def caused my issue. I’m not on testing either!
on plasma no problem,I have two pcs in testings
No problem on Cinnamon or Xfce or KDE.
