[tip & trick] Picom and @include
Picom supports @include for modular config files
Not sure how many people know this, but picom has an @include directive that lets you split your config into separate files per application.
The idea
Instead of stuffing all window rules into one file, picom supports @include directives. You keep a lean main config and put per-app rules in separate small files. Easy to read, easy to tweak.
The folder structure
~/.config/picom/
├── configs/
│   └── mabox-jaskier.conf       ← main picom config
└── include/
    ├── mabox-rules.conf          ← master rules file
    ├── kitty.conf
    ├── geany.conf
    ├── volbar.conf
    └── ...                       ← one file per app
How it works
Step 1 — At the bottom of your main picom config, include the rules file:
@include "mabox-rules.conf";
Picom looks for included files relative to the config, or in ~/.config/picom/include/.
Step 2 — In mabox-rules.conf, you open a rules: block and include each app config inside it:
rules: (
        @include "kitty.conf"
        @include "geany.conf"
Step 3 — Each app file contains just its match rule and settings:
# kitty.conf
match = "class_g = 'kitty'";
blur-background = false;
opacity = 1.0;
dim = 0.0;
animations = (
      triggers = ["open"];
      preset = "fly-in";
      direction = "down";
      duration = 0.5;
https://man.archlinux.org/man/picom.1
When @include directive is used in the config file, picom will first search for the included file in the parent directory of picom.conf, then in $XDG_CONFIG_HOME/picom/include/, then in $XDG_CONFIG_DIRS/picom/include.
This git has examples of configs to get a better idea.
:penguin: have fun…
