It s interesting that I can [CTRL] P pretty much any file, and I get the option to print a pdf. It s the default if there is no printer installed. At the very least, pdf creation is already in Linux. Are programmers too busy thinking outside the box to notice that there is something already inside the box…
Technically speaking that is the correct answer. Linux as in the kernel and core OS tools don’t provide PDF editing, but some 3rd party userland application/tools which happens to run on Linux.
If I would have asked you the same questiob no doubt the answer would be the same. I think you missed my point. It is probably general consesis that Linux has no built in pdf app, yet can create one…
The answer is right, it’s about editing an existing pdf document, not about creating one.
The answer could be Libre Office Draw, since it’s installed by default in many distros, but it’s not really reliable.
Adobe is the inventor of the long time proprietary pdf format and a designated source of information by the duck AI, while selling a set of tools for pdf editing. Adobe Acrobat, etc.
I’m not sure we should get too hung up on what a search engine’s LLM says about stuff. The moment we resign ourselves to believing everything it says… well
Take this example. If I ask it what time zone it is in Sydney Australia, it correctly tells me everything, except the timezone! The time and date are correct, the UTC offset is correct, but the timezone is wrong! The answer it gives is AEDT, when in fact it’s currently AEST (Australian Eastern Standard Time) in Sydney.
It knows this though. If I ask it about the AEDT timezone, it then gives me a correct representation of AEDT time (which is not current Sydney time).
AI “hallucinations” aside, by the answers presented here it seems ai s answer was correct in this instance. I always thought it was such a base function that it belonged to the kernel. That shows what I know I guess…
I don’t see the point of using AI search for time zones, we have enough specific sites for that.
And as long as you have the local time and UTC offset, it’s fine, unless someone mentioned something like “21:20 AEST” the timezone is not relevant.
I have a script which grep in /usr/share/zoneinfo/, no risk of half good answers.
tz.sh Sydney
Australia/Sydney jeu. 2026-04-23 21:26:44 +1000
I know about adobe, and the fact that pdf format is from them. I see the connection, As I see that in Linux one can print to a pdf if no printer is installed, Seems like it s been that way forever. Actually it s the same with Windows. Print to pdf is the default if no printer on a windows machine. Whether it s good or bad third party apps that make this possible I don t really care. I could do without the format to tell you the truth…
So uh… don’t use it? It’s an open source ISO standard (ISO 32000) that’s been set as default to eliminate the need for additional software to be installed. The whole point of pdf is that it standardises the layout, fonts and images for a document. It’s incredibly useful, more so in some industries where form content and legal documentation is prevalent.
Ignore AI, it will hallucinate to hell. Use whatever document format you need to get whatever task you’re doing, done. That might be pdf, odt, or anything in between.
