After updating to Plasma 6.7.0 yesterday, the temperature of my AMD RX550 graphics card stopped showing up in Thermal Monitor 0.2.7. The graphics card sensor has disappeared. However, the temperature is displayed in Psensors Edge. Could someone tell me how to set up Thermal Monitor?
The same thing happened on my laptop with AMD Radeon 890m.
Not really,
but reporting a new issue on the associated github might be helpful to notify the developer that there is an problem with Plasma 6.7.0.
Up so far, no similiar reports therer yet. But that might only due to a limited usage of that specific widget. Personally, I try to only use a bare minimum in terms of plasma widgets. There might be alternative widgets which aren’t broken at the moment.
I was able to fix the thermal monitor and sensor by following the instructions:
