The problem with booting the system
It still doesn’t work out :worried:
@VlPo
sudo mount -o subvol=@ /dev/nvme0n1p2 /mnt
sudo mount /dev/nvme0n1p1 /mnt/boot/efi
sudo arch-chroot /mnt
Edit: I hope i got it right. :wink:
Edit: https://wiki.archlinux.org/title/Chroot#Running_on_Btrfs
yes always the same row mount root system on /mnt and the esp efi into it /mnt/boot/efi looks like you rebooted in between.
THANK YOU SO MUCH FOR YOUR HELP!
Everything worked out and the system booted up normally :+1:
that`s good to hear !
