hi and good day dear Dalto - many thanks for the quick reply
AUR Update-Check:
:: Durchsuche AUR nach Updates...
:: 1 Pakete zu aktualisieren.
1 aur/celt 0.11.3-4 -> 0.11.3-5
==> Pakete zum AusschlieĂźen: (z.B. "1 2 3", "1-3", "^4" oder Repo-Name)
==> rm /var/lib/pacman/db.lck
:: Prüfe auf mögliche Konflikte...
:: Prüfe auf mögliche interne Konflikte...
[Aur:1] celt-0.11.3-5
1 celt (Installiert) (Build-Dateien sind vorhanden)
==> Pakete fĂĽr neuen Build?
==> [N] Keine [A]lle [Ab]brechen [I]nstalliert [No]nicht installiert oder (1 2 3, 1-3, ^4)
==> LANG=C sudo pacman
:: PKGBUILD aktuell, ĂĽberspringe (1/0): celt
==> Diffs zeigen?
i am willing to follow your recommendations - but evey time i enter the command to switch the terminal - lang - then i get some replies as mentioned above
do i something wrong - srry - if so. I am willing to work on the solution…!!!
hi pebcak hi pycrk
first of all : many many thanks for the quick reply - i am very glad.
now it runs - i did all - i entered all the commands you gave.
BTW: i runned into these kinds of errors some times -(repeadedly) i now have to digg deeper into the backgrounds - in order to learn what stops me …
update_ now the full update was possible all runned nicely - and i am glad
see the full list - what happened:
and yes - now i have to digg deeper to see what are my issues - /(that i am struggling so often with)…
now the system recommends the reboot - due to the update of the core system packages
update 2
see what is my main problem - see what causes soooo many issues - this is the issue i am struggling for so many times. I HAVE to get the fix - that helps me to go rund this issue.
error: failed to synchronize all databases (unable to lock database)
[martin@martineos ~]$ sudo fuser /var/lib/pacman/db.lck
[sudo] Passwort fĂĽr martin:
[martin@martineos ~]$ sudo rm /var/lib/pacman/db.lck
if i know what helps here - then i will get more confident to use EndeavourOS
btw: later the day i am installing a fresh EndeavourOS on the Notebook of my girlfriend.
I need to get more insights into the issues - so that i do not run into the db-locks in the next times…
update:4
the fix might be this here - the solution - i guess that these lines represent the solution for my issues… - in other words - if it comes to eerors with the db (if this is locked) then i have to look at the following lines
pebcak: mentioned:
First make sure no other instance of package manager is running on your system:
LANG=C sudo fuser /var/lib/pacman/db.lck
Then run again:
LANG=C sudo pacman -Syu
this i will learn by heart - this seems to be the solution
