Looking for an offline text-to-speech app . Years ago I had used Cainteoir and did find in aur but says error missing cainteoir engine .
Any advice on what to use now days ? Wishing for something easy to install ,has a GUI , and usable offline .
Will check back tonite to see what is recommended … Thanks !
Try these, all are in the repos:
GUI frontends:
Since we are at it, is there a speech to text that one can recommend?
Thank you kresimir … Will get that setup … now wondering what’s recommended for Zircon34 for speech-to-text .
Thank you for your time and recommendation !
Glorious new avatar.
