Hi, here’s the end results of paru -Syyu today, and it does that for all the aforementioned Aur packages seemingly ? I removed one and reinstalled it, and it showed the same emsasge for the next package.
Plenty of other packages were upgraded correctly but these, no.
:: Calculating internal conflicts...
:: marked as not up-to-date : dtrx simple-usb-automount
Aur (4) ocenaudio-bin-3.11.7-1 ocrmypdf-13.4.1-1 ani-cli-git-r481.1e97d1f-1 weechat-minimal-git-2.7.125.gc29b45a0f-1
:: Proceed to proofreading ? [Y/n] Y
:: Downloading PKGBUILDs...
error: command failed: /home/drm/.cache/paru/clone/ocenaudio-bin: git fetch -v:
fatal: neither this nor any of its parent directories is a git repository: .git
Should I install paru as well and adopt a wait and see approach?
Is there any problem having both installed, since they use the same pacman db?
As a non-dev user does it make any difference iif it based on rust or go?
I don’t think there is a reason to take a “wait and see approach”. The talk about yay’s demise was just a bunch of internet nonsense. There are many AUR helpers and these are just two of them. Of course, if you want both installed, go for it.
Having both installed won’t hurt anything. However, if you have any devel packages, the behaviour will be a bit odd if you switch back and forth since they both maintain a database of devel packages. Also, PKGBUILD diffs won’t work as well if you are switching back and forth. I recommend picking the one you prefer and sticking with it.
paru/rust takes longer to build when there is an update but it runs faster. yay/go is the opposite.
