systemd-udevd[314]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Anyone knows what causes this? I suspect there is a plugin or something that tries to check on hardware? Nothing dangerous but just curious.
inxi -Fxxxza --no-host
What exactly are we looking for? it’s a big chunk of data…
It is a standard help request. Hard to help without knowing the hardware involved. BIOS info, kernel etc…
System: Kernel: 5.10.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=07d6b3fc-6ee3-4575-b507-ea06675c2ccb rw
rootflags=subvol=@ quiet loglevel=3 nowatchdog
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0 Distro: EndeavourOS
Machine: Type: Desktop System: LENOVO product: 90JL00E8MW v: Legion T530-28ICB serial: <filter> Chassis: type: 3
serial: <filter>
Mobo: LENOVO model: 36E7 v: SDK0J40700 WIN 3258129188066 serial: <filter> UEFI: LENOVO v: O3LKT20A date: 03/07/2019
CPU: Info: 6-Core model: Intel Core i5-8400 bits: 64 type: MCP arch: Kaby Lake note: check family: 6 model-id: 9E (158)
stepping: A (10) microcode: DE L2 cache: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 33599
Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX disabled
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: mds mitigation: Clear CPU buffers; SMT disabled
Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel UHD Graphics 630 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e92
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI driver: nvidia v: 460.32.03
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1c82
Display: x11 server: X.org 1.20.10 driver: nvidia resolution: <missing: xdpyinfo>
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 01:00.1 chip ID: 10de:0fb9
Device-3: GN Netcom Jabra EVOLVE 65 type: USB driver: jabra,snd-usb-audio,usbhid bus ID: 1-3:2 chip ID: 0b0e:030c
serial: <filter>
Sound Server: ALSA v: k5.10.8-zen1-1-zen
Network: Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Lenovo driver: rtw_8821ce v: N/A
modules: rtw88_8821ce port: 4000 bus ID: 03:00.0 chip ID: 10ec:c821
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
bus ID: 04:00.0 chip ID: 10ec:8168
IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 4.66 TiB used: 8.58 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM128GDHTNG-8310B size: 119.24 GiB block size:
physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter> rev: 80070C00 temp: 39.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0 size: 931.51 GiB block size:
physical: 4096 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 1A02
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital model: WD40EZRX-00SPEB0 size: 3.64 TiB block size:
physical: 4096 B logical: 4096 B serial: <filter> rev: 1065
Partition: ID-1: / raw size: 48 GiB size: 48 GiB (100.00%) used: 8.53 GiB (17.8%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: /boot/efi raw size: 260 MiB size: 256 MiB (98.46%) used: 52.3 MiB (20.4%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw size: 48 GiB size: 48 GiB (100.00%) used: 8.53 GiB (17.8%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 56.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 29%
Info: Processes: 254 Uptime: 6m wakeups: 0 Memory: 15.51 GiB used: 1.72 GiB (11.1%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 935 lib: 276 Shell: fish v: 3.1.2 running in: xfce4-terminal inxi: 3.2.01
It is related to intel p_state. Old one that should have been fixed. Maybe reared its head again with new kernel.
So adjust BIOS settings or add a kernel parameter.
Thank you!
I also didn’t realize until now I forgot to set a Swap in my new partition scheme. Oh well.
You have 16Gib of ram so unless you use VM’s regularly should be ok. You could always add a swapfile after.
Oh I know, it’s more habit.
I’ve just got this error
but I didn’t understand the solution
please, could you explain me how you solved the problem?
What kernel do you use, because this should be fixed by now?
last kernel, zen
Huh, I didn’t get that error after today’s update.
And I have reinstalled completely since that post, several times too, so the solution then can’t have stuck.
Does it work with another kernel for you?
I’ve got the same error with the “normal” kernel, not the zen one
I have the same error with last “regular” kernel too Kernel: 5.13.9-arch1-1
