I get the following message in my logs pretty much with every reboot or when I shutdown the system.
nov 08 19:11:09 EndeavourOS systemd-coredump[73546]: Failed to connect to coredump service: Connection refused
Here is the the journal arround the time the error occurs:
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Session 2 of User backoff...
nov 08 19:11:09 EndeavourOS systemd[1]: Removed slice Slice /system/getty.
nov 08 19:11:09 EndeavourOS systemd[1]: Removed slice Slice /system/modprobe.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped target Bluetooth Support.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped target Graphical Interface.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped target Multi-User System.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped target Login Prompts.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped target Sound Card.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped target Timer Units.
nov 08 19:11:09 EndeavourOS systemd[1]: archlinux-keyring-wkd-sync.timer: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Refresh existing PGP keys of archlinux-keyring regularly.
nov 08 19:11:09 EndeavourOS systemd[1]: fstrim.timer: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Discard unused blocks once a month fool!.
nov 08 19:11:09 EndeavourOS systemd[1]: logrotate.timer: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Daily rotation of log files.
nov 08 19:11:09 EndeavourOS systemd[1]: man-db.timer: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Daily man-db regeneration.
nov 08 19:11:09 EndeavourOS systemd[1]: shadow.timer: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Daily verification of password and group files.
nov 08 19:11:09 EndeavourOS systemd[1]: systemd-tmpfiles-clean.timer: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Daily Cleanup of Temporary Directories.
nov 08 19:11:09 EndeavourOS systemd[1]: updatedb.timer: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Daily locate database update.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped target System Time Set.
nov 08 19:11:09 EndeavourOS systemd[1]: lvm2-lvmpolld.socket: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Closed LVM2 poll daemon socket.
nov 08 19:11:09 EndeavourOS systemd[1]: systemd-coredump.socket: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Closed Process Core Dump Socket.
nov 08 19:11:09 EndeavourOS systemd[1]: systemd-rfkill.socket: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Accounts Service...
nov 08 19:11:09 EndeavourOS polkitd[532]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.27, object path /org/gnome/PolicyKit1/AuthenticationA>
nov 08 19:11:09 EndeavourOS kernel: kauditd_printk_skb: 17 callbacks suppressed
nov 08 19:11:09 EndeavourOS kernel: audit: type=1113 audit(1667931069.506:161): pid=659 uid=0 auid=1000 ses=2 msg='op=logout id=1000 exe="/usr/bin/lightdm" hostname=End>
nov 08 19:11:09 EndeavourOS kernel: audit: type=1106 audit(1667931069.516:162): pid=659 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyini>
nov 08 19:11:09 EndeavourOS kernel: audit: type=1104 audit(1667931069.516:163): pid=659 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_p>
nov 08 19:11:09 EndeavourOS kernel: traps: mullvad-gui[6780] trap int3 ip:55f43a0af9df sp:7fff23133560 error:0 in mullvad-gui[55f436f80000+6c47000]
nov 08 19:11:09 EndeavourOS kernel: audit: type=1701 audit(1667931069.523:164): auid=1000 uid=1000 gid=1000 ses=2 pid=6780 comm="mullvad-gui" exe=2F6F70742F4D756C6C7661>
nov 08 19:11:09 EndeavourOS audit[659]: USER_END pid=659 uid=0 auid=1000 ses=2 msg='op=PAM:session_close grantors=pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,p>
nov 08 19:11:09 EndeavourOS audit[659]: CRED_DISP pid=659 uid=0 auid=1000 ses=2 msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock acct="backo>
nov 08 19:11:09 EndeavourOS audit[6780]: ANOM_ABEND auid=1000 uid=1000 gid=1000 ses=2 pid=6780 comm="mullvad-gui" exe=2F6F70742F4D756C6C7661642056504E2F6D756C6C7661642D>
nov 08 19:11:09 EndeavourOS dunst[1026]: X connection to :0 broken (explicit kill or server shutdown).
nov 08 19:11:09 EndeavourOS lightdm[659]: pam_unix(lightdm:session): session closed for user backoff
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Save/Restore Sound Card State...
nov 08 19:11:09 EndeavourOS at-spi-bus-launcher[806]: X connection to :0 broken (explicit kill or server shutdown).
nov 08 19:11:09 EndeavourOS avahi-daemon[494]: Got SIGTERM, quitting.
nov 08 19:11:09 EndeavourOS systemd[695]: dunst.service: Main process exited, code=exited, status=1/FAILURE
nov 08 19:11:09 EndeavourOS avahi-daemon[494]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.2.10.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
nov 08 19:11:09 EndeavourOS avahi-daemon[494]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1.
nov 08 19:11:09 EndeavourOS systemd[695]: dunst.service: Failed with result 'exit-code'.
nov 08 19:11:09 EndeavourOS avahi-daemon[494]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Bluetooth service...
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Terminating
nov 08 19:11:09 EndeavourOS systemd[695]: dunst.service: Consumed 1.086s CPU time.
nov 08 19:11:09 EndeavourOS avahi-daemon[494]: avahi-daemon 0.8 exiting.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Light Display Manager...
nov 08 19:11:09 EndeavourOS systemd[1]: Starting Generate shutdown-ramfs...
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [mullvad_daemon::shutdown::platform][DEBUG] Process received signal: [Term]
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Mullvad VPN daemon...
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Authorization Manager...
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Power Profiles daemon...
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Load/Save Random Seed...
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Disk Manager...
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping Daemon for power management...
nov 08 19:11:09 EndeavourOS systemd[1]: avahi-daemon.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostn>
nov 08 19:11:09 EndeavourOS systemd[1]: accounts-daemon.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Accounts Service.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" ho>
nov 08 19:11:09 EndeavourOS systemd[1]: rtkit-daemon.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostn>
nov 08 19:11:09 EndeavourOS systemd[1]: alsa-restore.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Save/Restore Sound Card State.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/usr/lib/systemd/systemd" hostn>
nov 08 19:11:09 EndeavourOS systemd-logind[498]: Session 2 logged out. Waiting for processes to exit.
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [mullvad_daemon][DEBUG] Blocking firewall during shutdown since system is going down
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [talpid_core::dns][INFO] Resetting DNS
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [talpid_core::routing::imp::imp][DEBUG] Clearing routes
nov 08 19:11:09 EndeavourOS wireplumber[808]: dbus[808]: Attempted to unregister path (path[0] = MediaEndpoint path[1] = A2DPSink) which isn't registered
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [mullvad_daemon][DEBUG] New tunnel state: Disconnecting(Nothing)
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/ldac
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSink/aptx_hd
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/aptx_hd
nov 08 19:11:09 EndeavourOS kernel: audit: type=1131 audit(1667931069.536:165): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=avahi-daemon comm="systemd" exe="/u>
nov 08 19:11:09 EndeavourOS kernel: audit: type=1131 audit(1667931069.536:166): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=accounts-daemon comm="systemd" exe=>
nov 08 19:11:09 EndeavourOS kernel: audit: type=1131 audit(1667931069.536:167): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/u>
nov 08 19:11:09 EndeavourOS kernel: audit: type=1131 audit(1667931069.536:168): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=alsa-restore comm="systemd" exe="/u>
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSink/aac
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/aac
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSink/sbc
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/sbc
nov 08 19:11:09 EndeavourOS NetworkManager[503]: <info> [1667931069.5438] device (wg-mullvad): state change: activated -> unmanaged (reason 'unmanaged', sys-iface-stat>
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSink/sbc_xq
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/sbc_xq
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/aptx_ll_1
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/aptx_ll_0
nov 08 19:11:09 EndeavourOS dbus-daemon[496]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.ser>
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
nov 08 19:11:09 EndeavourOS dbus-daemon[496]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus i>
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/faststream
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/faststream_duplex
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSink/opus_05
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/opus_05
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/opus_05_51
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/opus_05_71
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSink/opus_05_duplex
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/opus_05_duplex
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Endpoint unregistered: sender=:1.947 path=/MediaEndpoint/A2DPSource/opus_05_pro
nov 08 19:11:09 EndeavourOS systemd[1]: systemd-random-seed.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Load/Save Random Seed.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd>
nov 08 19:11:09 EndeavourOS mkinitcpio[73547]: ==> Starting build: none
nov 08 19:11:09 EndeavourOS kernel: audit: type=1131 audit(1667931069.543:169): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" >
nov 08 19:11:09 EndeavourOS mkinitcpio[73547]: -> Running build hook: [sd-shutdown]
nov 08 19:11:09 EndeavourOS systemd[1]: polkit.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Authorization Manager.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? >
nov 08 19:11:09 EndeavourOS systemd[1]: power-profiles-daemon.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Power Profiles daemon.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=power-profiles-daemon comm="systemd" exe="/usr/lib/systemd/syste>
nov 08 19:11:09 EndeavourOS udisksd[16501]: udisks daemon version 2.9.4 exiting
nov 08 19:11:09 EndeavourOS audit[16501]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 pid=16501 comm="udisksd" exe="/usr/lib/udisks2/udisksd" sig=6 res=1
nov 08 19:11:09 EndeavourOS udisksd[16501]: **
nov 08 19:11:09 EndeavourOS udisksd[16501]: GLib-GIO:ERROR:../glib/gio/gresource.c:1451:g_static_resource_fini: assertion failed: (g_atomic_int_get (&resource->ref_coun>
nov 08 19:11:09 EndeavourOS udisksd[16501]: Bail out! GLib-GIO:ERROR:../glib/gio/gresource.c:1451:g_static_resource_fini: assertion failed: (g_atomic_int_get (&resource>
nov 08 19:11:09 EndeavourOS systemd[1]: session-2.scope: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Session 2 of User backoff.
nov 08 19:11:09 EndeavourOS systemd[1]: session-2.scope: Consumed 3h 32min 57.058s CPU time.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping User Login Management...
nov 08 19:11:09 EndeavourOS systemd[1]: Stopping User Manager for UID 1000...
nov 08 19:11:09 EndeavourOS systemd-logind[498]: Removed session 2.
nov 08 19:11:09 EndeavourOS systemd[695]: Activating special unit Exit the Session...
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped target Bluetooth.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped target Main User Target.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopping Accessibility services bus...
nov 08 19:11:09 EndeavourOS gvfsd[763]: A connection to the bus can't be made
nov 08 19:11:09 EndeavourOS systemd[695]: Stopping D-Bus User Message Bus...
nov 08 19:11:09 EndeavourOS systemd[695]: Stopping Virtual filesystem service...
nov 08 19:11:09 EndeavourOS systemd[695]: Stopping Virtual filesystem metadata service...
nov 08 19:11:09 EndeavourOS systemd[695]: Stopping Virtual filesystem service - disk device monitor...
nov 08 19:11:09 EndeavourOS systemd[695]: Stopping PipeWire PulseAudio...
nov 08 19:11:09 EndeavourOS systemd-coredump[73603]: Failed to connect to coredump service: Connection refused
nov 08 19:11:09 EndeavourOS systemd[1]: run-user-1000-gvfs.mount: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Unmounted /run/user/1000/gvfs.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?>
nov 08 19:11:09 EndeavourOS systemd[1]: udisks2.service: Main process exited, code=dumped, status=6/ABRT
nov 08 19:11:09 EndeavourOS systemd[1]: udisks2.service: Failed with result 'core-dump'.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Disk Manager.
nov 08 19:11:09 EndeavourOS systemd[1]: udisks2.service: Consumed 1.757s CPU time.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped D-Bus User Message Bus.
nov 08 19:11:09 EndeavourOS systemd[695]: dbus.service: Consumed 1.439s CPU time.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped PipeWire PulseAudio.
nov 08 19:11:09 EndeavourOS systemd[695]: pipewire-pulse.service: Consumed 53.533s CPU time.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped Virtual filesystem service - disk device monitor.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped Virtual filesystem metadata service.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped Virtual filesystem service.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopping Multimedia Service Session Manager...
nov 08 19:11:09 EndeavourOS wireplumber[808]: stopped by signal: Terminated
nov 08 19:11:09 EndeavourOS wireplumber[808]: disconnected from pipewire
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped Multimedia Service Session Manager.
nov 08 19:11:09 EndeavourOS systemd[695]: wireplumber.service: Consumed 1min 3.417s CPU time.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopping PipeWire Multimedia Service...
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped PipeWire Multimedia Service.
nov 08 19:11:09 EndeavourOS systemd[695]: pipewire.service: Consumed 23.849s CPU time.
nov 08 19:11:09 EndeavourOS mkinitcpio[73547]: ==> Build complete.
nov 08 19:11:09 EndeavourOS systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Finished Generate shutdown-ramfs.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib>
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/>
nov 08 19:11:09 EndeavourOS systemd[1]: upower.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Daemon for power management.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? >
nov 08 19:11:09 EndeavourOS audit: BPF prog-id=0 op=UNLOAD
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [talpid_core::tunnel_state_machine::connecting_state][DEBUG] Tunnel monitor exited with block reason: None
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [talpid_core::firewall][INFO] Applying firewall policy: Blocked. Allowing LAN. Allowing endpoint: 45.83.222.100:443/TCP
nov 08 19:11:09 EndeavourOS audit[544]: NETFILTER_CFG table=mullvadmangle6:26 family=10 entries=5 op=nft_register_chain pid=544 comm="tokio-runtime-w"
nov 08 19:11:09 EndeavourOS audit[544]: NETFILTER_CFG table=mullvadmangle6:26 family=10 entries=6 op=nft_unregister_table pid=544 comm="tokio-runtime-w"
nov 08 19:11:09 EndeavourOS audit[544]: NETFILTER_CFG table=mullvadmangle4:26 family=2 entries=5 op=nft_register_chain pid=544 comm="tokio-runtime-w"
nov 08 19:11:09 EndeavourOS audit[544]: NETFILTER_CFG table=mullvadmangle4:26 family=2 entries=8 op=nft_unregister_table pid=544 comm="tokio-runtime-w"
nov 08 19:11:09 EndeavourOS audit[544]: NETFILTER_CFG table=mullvad:26 family=1 entries=79 op=nft_register_chain pid=544 comm="tokio-runtime-w"
nov 08 19:11:09 EndeavourOS audit[544]: NETFILTER_CFG table=mullvad:26 family=1 entries=90 op=nft_unregister_table pid=544 comm="tokio-runtime-w"
nov 08 19:11:09 EndeavourOS audit[531]: SYSCALL arch=c000003e syscall=44 success=yes exit=35896 a0=e a1=7eff48038dc0 a2=8c38 a3=0 items=0 ppid=1 pid=531 auid=4294967295>
nov 08 19:11:09 EndeavourOS audit: PROCTITLE proctitle=2F7573722F62696E2F6D756C6C7661642D6461656D6F6E002D76002D2D64697361626C652D7374646F75742D74696D657374616D7073
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [mullvad_daemon][DEBUG] New tunnel state: Disconnected
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [mullvad_daemon::device][DEBUG] Account manager has stopped
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [talpid_core::tunnel_state_machine][DEBUG] Exiting tunnel state machine loop
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [talpid_core::tunnel_state_machine][INFO] Tunnel state machine shut down
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [mullvad_daemon][INFO] Mullvad daemon is quitting
nov 08 19:11:09 EndeavourOS mullvad-daemon[531]: [mullvad_daemon::management_interface][INFO] Management interface shut down
nov 08 19:11:09 EndeavourOS systemd[1]: systemd-logind.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped User Login Management.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hos>
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Stopping SDP server
nov 08 19:11:09 EndeavourOS bluetoothd[501]: Exit
nov 08 19:11:09 EndeavourOS systemd[1]: bluetooth.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Bluetooth service.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname>
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped Accessibility services bus.
nov 08 19:11:09 EndeavourOS systemd[695]: at-spi-dbus-bus.service: Consumed 4.540s CPU time.
nov 08 19:11:09 EndeavourOS systemd[695]: Removed slice User Core Session Slice.
nov 08 19:11:09 EndeavourOS systemd[695]: session.slice: Consumed 2min 27.538s CPU time.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped target Basic System.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped target Paths.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped target Sockets.
nov 08 19:11:09 EndeavourOS systemd[695]: Stopped target Timers.
nov 08 19:11:09 EndeavourOS systemd[695]: Closed D-Bus User Message Bus Socket.
nov 08 19:11:09 EndeavourOS systemd[695]: Closed GnuPG network certificate management daemon.
nov 08 19:11:09 EndeavourOS systemd[695]: Closed GCR ssh-agent wrapper.
nov 08 19:11:09 EndeavourOS systemd[695]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
nov 08 19:11:09 EndeavourOS systemd[695]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
nov 08 19:11:09 EndeavourOS systemd[695]: Closed GnuPG cryptographic agent (ssh-agent emulation).
nov 08 19:11:09 EndeavourOS systemd[695]: Closed GnuPG cryptographic agent and passphrase cache.
nov 08 19:11:09 EndeavourOS systemd[695]: Closed p11-kit server.
nov 08 19:11:09 EndeavourOS systemd[695]: Closed PipeWire PulseAudio.
nov 08 19:11:09 EndeavourOS systemd[695]: Closed PipeWire Multimedia System Socket.
nov 08 19:11:09 EndeavourOS systemd[695]: Removed slice User Application Slice.
nov 08 19:11:09 EndeavourOS systemd[695]: app.slice: Consumed 1.089s CPU time.
nov 08 19:11:09 EndeavourOS systemd[695]: Reached target Shutdown.
nov 08 19:11:09 EndeavourOS systemd[695]: Finished Exit the Session.
nov 08 19:11:09 EndeavourOS systemd[695]: Reached target Exit the Session.
nov 08 19:11:09 EndeavourOS systemd[1]: lightdm.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped Light Display Manager.
nov 08 19:11:09 EndeavourOS systemd[1]: lightdm.service: Consumed 8min 30.781s CPU time.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lightdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?>
nov 08 19:11:09 EndeavourOS systemd[696]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[backoff] ruser>
nov 08 19:11:09 EndeavourOS systemd[1]: user@1000.service: Deactivated successfully.
nov 08 19:11:09 EndeavourOS systemd[1]: Stopped User Manager for UID 1000.
nov 08 19:11:09 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname>
nov 08 19:11:09 EndeavourOS systemd[1]: user@1000.service: Consumed 2min 28.805s CPU time.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopping User Runtime Directory /run/user/1000...
nov 08 19:11:10 EndeavourOS systemd[1]: run-user-1000.mount: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Unmounted /run/user/1000.
nov 08 19:11:10 EndeavourOS systemd[1]: user-runtime-dir@1000.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped User Runtime Directory /run/user/1000.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/syste>
nov 08 19:11:10 EndeavourOS systemd[1]: Removed slice User Slice of UID 1000.
nov 08 19:11:10 EndeavourOS systemd[1]: user-1000.slice: Consumed 3h 35min 25.875s CPU time.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopping Permit User Sessions...
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-user-sessions.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Permit User Sessions.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/syste>
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Network.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target User and Group Name Lookups.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Remote File Systems.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopping WPA supplicant...
nov 08 19:11:10 EndeavourOS wpa_supplicant[583]: p2p-dev-wlan0: CTRL-EVENT-DSCP-POLICY clear_all
nov 08 19:11:10 EndeavourOS wpa_supplicant[583]: nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0
nov 08 19:11:10 EndeavourOS wpa_supplicant[583]: p2p-dev-wlan0: CTRL-EVENT-TERMINATING
nov 08 19:11:10 EndeavourOS kernel: wlan0: deauthenticating from dc:15:c8:1c:71:56 by local choice (Reason: 3=DEAUTH_LEAVING)
nov 08 19:11:10 EndeavourOS mullvad-daemon[531]: [mullvad_daemon][DEBUG] Process exiting with code 0
nov 08 19:11:10 EndeavourOS systemd[1]: mullvad-daemon.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Mullvad VPN daemon.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mullvad-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hos>
nov 08 19:11:10 EndeavourOS systemd[1]: mullvad-daemon.service: Consumed 7.100s CPU time.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopping Network Manager...
nov 08 19:11:10 EndeavourOS NetworkManager[503]: <info> [1667931070.2553] caught SIGTERM, shutting down normally.
nov 08 19:11:10 EndeavourOS wpa_supplicant[583]: wlan0: CTRL-EVENT-DISCONNECTED bssid=dc:15:c8:1c:71:56 reason=3 locally_generated=1
nov 08 19:11:10 EndeavourOS NetworkManager[503]: <info> [1667931070.3067] device (wlan0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state:>
nov 08 19:11:10 EndeavourOS wpa_supplicant[583]: wlan0: CTRL-EVENT-DSCP-POLICY clear_all
nov 08 19:11:10 EndeavourOS NetworkManager[503]: <info> [1667931070.3073] manager: NetworkManager state is now DISCONNECTING
nov 08 19:11:10 EndeavourOS dbus-daemon[496]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.ser>
nov 08 19:11:10 EndeavourOS dbus-daemon[496]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus i>
nov 08 19:11:10 EndeavourOS NetworkManager[503]: <warn> [1667931070.3101] dispatcher: (58) failed (after 0.002 sec): Refusing activation, D-Bus is shutting down.
nov 08 19:11:10 EndeavourOS NetworkManager[503]: <info> [1667931070.3106] device (wlan0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: '>
nov 08 19:11:10 EndeavourOS wpa_supplicant[583]: wlan0: PMKSA-CACHE-REMOVED dc:15:c8:1c:71:56 0
nov 08 19:11:10 EndeavourOS wpa_supplicant[583]: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nov 08 19:11:10 EndeavourOS wpa_supplicant[583]: wlan0: CTRL-EVENT-TERMINATING
nov 08 19:11:10 EndeavourOS NetworkManager[503]: <info> [1667931070.4040] manager: NetworkManager state is now DISCONNECTED
nov 08 19:11:10 EndeavourOS systemd[1]: wpa_supplicant.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped WPA supplicant.
nov 08 19:11:10 EndeavourOS NetworkManager[503]: <info> [1667931070.4087] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'removed', sys-iface->
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hos>
nov 08 19:11:10 EndeavourOS NetworkManager[503]: <info> [1667931070.4287] exiting (success)
nov 08 19:11:10 EndeavourOS systemd[1]: NetworkManager.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Network Manager.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hos>
nov 08 19:11:10 EndeavourOS systemd[1]: NetworkManager.service: Consumed 2.848s CPU time.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopping D-Bus System Message Bus...
nov 08 19:11:10 EndeavourOS systemd[1]: dbus.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped D-Bus System Message Bus.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? ad>
nov 08 19:11:10 EndeavourOS systemd[1]: dbus.service: Consumed 2.406s CPU time.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Basic System.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Path Units.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Slice Units.
nov 08 19:11:10 EndeavourOS systemd[1]: Removed slice User and Session Slice.
nov 08 19:11:10 EndeavourOS systemd[1]: user.slice: Consumed 3h 35min 26.863s CPU time.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Socket Units.
nov 08 19:11:10 EndeavourOS systemd[1]: avahi-daemon.socket: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
nov 08 19:11:10 EndeavourOS systemd[1]: dbus.socket: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Closed D-Bus System Message Bus Socket.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target System Initialization.
nov 08 19:11:10 EndeavourOS systemd[1]: proc-sys-fs-binfmt_misc.automount: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Unset automount Arbitrary Executable File Formats File System Automount Point.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Local Encrypted Volumes.
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-ask-password-console.path: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-ask-password-wall.path: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Local Integrity Protected Volumes.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Local Verity Protected Volumes.
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-sysctl.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Apply Kernel Variables.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hos>
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-modules-load.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Load Kernel Modules.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/system>
nov 08 19:11:10 EndeavourOS systemd[1]: Stopping Network Time Synchronization...
nov 08 19:11:10 EndeavourOS systemd[1]: Stopping Record System Boot/Shutdown in UTMP...
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-timesyncd.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Network Time Synchronization.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" >
nov 08 19:11:10 EndeavourOS audit[73662]: SYSTEM_SHUTDOWN pid=73662 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd->
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-update-utmp.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Record System Boot/Shutdown in UTMP.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd>
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-tmpfiles-setup.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Create Volatile Files and Directories.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Local File Systems.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/syst>
nov 08 19:11:10 EndeavourOS systemd[1]: mnt-ToshibaHD.automount: Deactivated successfully.
nov 08 19:11:10 EndeavourOS audit: BPF prog-id=0 op=UNLOAD
nov 08 19:11:10 EndeavourOS systemd[1]: Unset automount mnt-ToshibaHD.automount.
nov 08 19:11:10 EndeavourOS systemd[1]: Unmounting /boot/efi...
nov 08 19:11:10 EndeavourOS systemd[1]: Unmounting /home/backoff/ramdisk...
nov 08 19:11:10 EndeavourOS systemd[1]: Unmounting Temporary Directory /tmp...
nov 08 19:11:10 EndeavourOS systemd[1]: boot-efi.mount: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Unmounted /boot/efi.
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-fsck@dev-disk-by\x2duuid-A86A\x2d35FE.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped File System Check on /dev/disk/by-uuid/A86A-35FE.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-A86A\x2d35FE comm="systemd" exe>
nov 08 19:11:10 EndeavourOS systemd[1]: Removed slice Slice /system/systemd-fsck.
nov 08 19:11:10 EndeavourOS systemd[1]: home-backoff-ramdisk.mount: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Unmounted /home/backoff/ramdisk.
nov 08 19:11:10 EndeavourOS systemd[1]: tmp.mount: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Unmounted Temporary Directory /tmp.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Preparation for Local File Systems.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped target Swaps.
nov 08 19:11:10 EndeavourOS systemd[1]: Deactivating swap /swapfile...
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-tmpfiles-setup-dev.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Create Static Device Nodes in /dev.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/>
nov 08 19:11:10 EndeavourOS systemd[1]: swapfile.swap: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Deactivated swap /swapfile.
nov 08 19:11:10 EndeavourOS systemd[1]: Reached target Unmount All Filesystems.
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-remount-fs.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Stopped Remount Root and Kernel File Systems.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd">
nov 08 19:11:10 EndeavourOS systemd[1]: Reached target System Shutdown.
nov 08 19:11:10 EndeavourOS systemd[1]: Reached target Late Shutdown Services.
nov 08 19:11:10 EndeavourOS systemd[1]: systemd-reboot.service: Deactivated successfully.
nov 08 19:11:10 EndeavourOS systemd[1]: Finished System Reboot.
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" ho>
nov 08 19:11:10 EndeavourOS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hos>
nov 08 19:11:10 EndeavourOS systemd[1]: Reached target System Reboot.
nov 08 19:11:10 EndeavourOS systemd[1]: Shutting down.
nov 08 19:11:10 EndeavourOS systemd-shutdown[1]: Syncing filesystems and block devices.
nov 08 19:11:10 EndeavourOS systemd-shutdown[1]: Sending SIGTERM to remaining processes...
nov 08 19:11:10 EndeavourOS systemd-journald[278]: Received SIGTERM from PID 1 (systemd-shutdow).
nov 08 19:11:10 EndeavourOS systemd-journald[278]: Journal stopped
My system: https://0x0.st/oEn-.txt
