Systemd-boot menu to small to read (Surface Pro 7)
Tried all of the console-mode settings and it stubbornly remains too small to read. Can’t find much out there, any ideas?
mayby try https://www.kernel.org/doc/Documentation/fb/modedb.rst video= kernel command?
What ringo said.
There is also a little known simple fix:
Press the R key when the boot loader appears. Keep tapping R to cycle through the different font sizes.
When you find one that you like then select a kernel to boot.
The font size will be remembered each boot.
Hope this works for you.
Doesn’t work, when I reinstall, will use grub as that is more configurable.
fairly to say i dont see my sysd-boot :slight_smile: only what i care about is my Endeavouros logo during boot of the bmp file at uki boot
