I m updating my system using yay and while update something new came up on terminal i haven’t use it before so id don’t what should i do next…
Need helpp…
You asked it to show you the diff between versions of an AUR package so it did.
Try pressing the key q
It’s up to you if you accept the package changes or not.
Is this your first time updating? This looks all very normal.
Nope not the first time but like this update i haven’t done before
I m newbie so dont’t know…
You may find this helpful:
https://discovery.endeavouros.com/aur/yay-an-aur-helper-written-in-go/2021/03/
If you want to update all those packages, just press “enter”
Thank u sir its solved !!!
There’s a lot of information here about updating. Someone even went out and wrote a fairly legnthy comprehensive guide to updating for beginners. It’s in the welcome thread you probably read if you’re new.
Thank your sir i will sure read it…
