System update gets stuck on checking which packages need to be rebuilt
After running pacman -Syu I got stuck on the above for like 10 minutes before I just ctrl+c’d it. It was clearly doing something cuz the fans were going crazy while it was ongoing, this is like the 3rd time it happens.
What’s up with this?
check your logs include necessary data to assist you. Right now we can only guess as you give no information.
Here’s the log, sorry about that.
https://0x0.st/X40K.txt
or at least it was supposed to be… maybe eos sendlog is broken? it seems to just 404, what data do you need exactly?
post your pacman log that will allow others to better see what the issue could be since you state:
Here is the portion of the pacman log when the problem occurred
[2024-08-17T08:05:47+0000] [PACMAN] Running 'pacman -Syu'
[2024-08-17T08:05:47+0000] [PACMAN] synchronizing package lists
[2024-08-17T08:05:49+0000] [PACMAN] starting full system upgrade
[2024-08-17T08:07:02+0000] [ALPM] running '90-kernel-remove.hook'...
[2024-08-17T08:07:02+0000] [ALPM-SCRIPTLET] :: kernel-install removing kernel 6.10.4-arch2-1
[2024-08-17T08:07:02+0000] [ALPM] transaction started
[2024-08-17T08:07:02+0000] [ALPM] upgraded alsa-card-profiles (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-17T08:07:03+0000] [ALPM] upgraded gnutls (3.8.6-1 -> 3.8.7-1)
[2024-08-17T08:07:03+0000] [ALPM] upgraded kmod (32-1 -> 33-1)
[2024-08-17T08:07:05+0000] [ALPM] upgraded breeze-icons (6.4.0-1 -> 6.5.0-1)
[2024-08-17T08:07:05+0000] [ALPM] upgraded librsvg (2:2.58.2-1 -> 2:2.58.3-1)
[2024-08-17T08:07:05+0000] [ALPM] upgraded gtk-update-icon-cache (1:4.14.4-2 -> 1:4.14.5-1)
[2024-08-17T08:07:05+0000] [ALPM] upgraded electron31 (31.3.1-1 -> 31.4.0-1)
[2024-08-17T08:07:05+0000] [ALPM] upgraded eos-translations (24.7-1 -> 24.8-1)
[2024-08-17T08:07:06+0000] [ALPM] upgraded fakeroot (1.35-1 -> 1.35.1-1)
[2024-08-17T08:07:06+0000] [ALPM] upgraded fastfetch (2.21.2-1 -> 2.21.3-1)
[2024-08-17T08:07:06+0000] [ALPM] upgraded libpipewire (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-17T08:07:06+0000] [ALPM] upgraded pipewire (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-17T08:07:07+0000] [ALPM] upgraded gst-plugin-pipewire (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-17T08:07:07+0000] [ALPM] upgraded gtk4 (1:4.14.4-2 -> 1:4.14.5-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded hyprpaper (0.7.0-2 -> 0.7.1-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded kcoreaddons (6.4.0-1 -> 6.5.0-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded kcrash (6.4.0-1 -> 6.5.0-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded kdbusaddons (6.4.0-1 -> 6.5.0-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded ki18n (6.4.0-1 -> 6.5.0-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded kirigami (6.4.0-2 -> 6.5.0-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded kitemmodels (6.4.0-1 -> 6.5.0-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded kwindowsystem (6.4.0-1 -> 6.5.0-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded lib32-gnutls (3.8.6-1 -> 3.8.7-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded lib32-libltdl (2.5.0+1+g38c166c8-1 -> 2.5.1-2)
[2024-08-17T08:07:07+0000] [ALPM] upgraded lib32-librsvg (2:2.58.2-1 -> 2:2.58.3-1)
[2024-08-17T08:07:07+0000] [ALPM] upgraded libssh (0.11.0-1 -> 0.11.0-2)
[2024-08-17T08:07:08+0000] [ALPM] upgraded linux (6.10.4.arch2-1 -> 6.10.5.arch1-1)
[2024-08-17T08:07:08+0000] [ALPM] upgraded nvidia (555.58.02-15 -> 555.58.02-16)
[2024-08-17T08:07:08+0000] [ALPM] upgraded pipewire-audio (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-17T08:07:08+0000] [ALPM] upgraded pipewire-alsa (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-17T08:07:08+0000] [ALPM] upgraded pipewire-jack (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-17T08:07:08+0000] [ALPM] upgraded pipewire-pulse (1:1.2.2-1 -> 1:1.2.2-2)
[2024-08-17T08:07:09+0000] [ALPM] upgraded playerctl (2.4.1-3 -> 2.4.1-4)
[2024-08-17T08:07:09+0000] [ALPM] upgraded pybind11 (2.13.3-1 -> 2.13.4-1)
[2024-08-17T08:07:09+0000] [ALPM] upgraded python-aiohappyeyeballs (2.3.5-1 -> 2.3.6-1)
[2024-08-17T08:07:09+0000] [ALPM] upgraded python-lxml (5.2.2-1 -> 5.3.0-1)
[2024-08-17T08:07:09+0000] [ALPM] upgraded python-sphinx-alabaster-theme (0.7.16-2 -> 1.0.0-1)
[2024-08-17T08:07:09+0000] [ALPM] upgraded python-sphinx_rtd_theme (1.3.0-2 -> 2.0.0-1)
[2024-08-17T08:07:09+0000] [ALPM] upgraded python-validate-pyproject (0.18-1 -> 0.19-1)
[2024-08-17T08:07:10+0000] [ALPM] upgraded signal-desktop (7.19.1-1 -> 7.20.0-1)
[2024-08-17T08:07:10+0000] [ALPM] upgraded steam (1.0.0.79-2 -> 1.0.0.81-1)
[2024-08-17T08:07:10+0000] [ALPM] upgraded webkit2gtk-4.1 (2.44.3-2 -> 2.44.3-3)
[2024-08-17T08:07:10+0000] [ALPM] transaction completed
[2024-08-17T08:07:11+0000] [ALPM] running '30-systemd-daemon-reload-user.hook'...
[2024-08-17T08:07:11+0000] [ALPM] running '30-systemd-udev-reload.hook'...
[2024-08-17T08:07:12+0000] [ALPM] running '30-systemd-update.hook'...
[2024-08-17T08:07:12+0000] [ALPM] running '30-update-mime-database.hook'...
[2024-08-17T08:07:12+0000] [ALPM] running '60-depmod.hook'...
[2024-08-17T08:07:14+0000] [ALPM] running '90-kernel-install.hook'...
[2024-08-17T08:07:14+0000] [ALPM-SCRIPTLET] :: kernel-install installing kernel 6.10.5-arch1-1
[2024-08-17T08:07:16+0000] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --no-hostonly --force /efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd-fallback 6.10.5-arch1-1
[2024-08-17T08:07:17+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-08-17T08:07:17+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-08-17T08:07:17+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-08-17T08:07:17+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-08-17T08:07:17+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-08-17T08:07:17+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-pcrphase ***
[2024-08-17T08:07:17+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-08-17T08:07:17+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-08-17T08:07:18+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-08-17T08:07:18+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-08-17T08:07:18+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: modsign ***
[2024-08-17T08:07:18+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-08-17T08:07:18+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: btrfs ***
[2024-08-17T08:07:18+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-08-17T08:07:18+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-08-17T08:07:18+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-08-17T08:07:20+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lvm ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: mdraid ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: nvdimm ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pcmcia ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu-net ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fido2 ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pkcs11 ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lunmask ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: resume ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-08-17T08:07:21+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: virtiofs ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-08-17T08:07:22+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-08-17T08:07:23+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-08-17T08:07:23+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-08-17T08:07:23+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-08-17T08:07:23+0000] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-08-17T08:07:24+0000] [ALPM-SCRIPTLET] dracut[I]: *** Constructing AuthenticAMD.bin ***
[2024-08-17T08:07:24+0000] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-08-17T08:07:24+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-08-17T08:07:24+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-08-17T08:07:24+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd-fallback' ***
[2024-08-17T08:07:29+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd-fallback' done ***
[2024-08-17T08:07:30+0000] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd 6.10.5-arch1-1
[2024-08-17T08:07:31+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-08-17T08:07:32+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-08-17T08:07:33+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pcmcia ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-08-17T08:07:34+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Constructing AuthenticAMD.bin ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-08-17T08:07:35+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd' ***
[2024-08-17T08:07:38+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd' done ***
[2024-08-17T08:07:39+0000] [ALPM] running 'eos-nvidia-fix.hook'...
[2024-08-17T08:07:39+0000] [ALPM-SCRIPTLET] Installing kernel 6.10.5-arch1-1
[2024-08-17T08:07:40+0000] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --no-hostonly --force /efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd-fallback 6.10.5-arch1-1
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-pcrphase ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: modsign ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: btrfs ***
[2024-08-17T08:07:41+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-08-17T08:07:42+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-08-17T08:07:42+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lvm ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: mdraid ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: nvdimm ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pcmcia ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: qemu-net ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fido2 ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pkcs11 ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: lunmask ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: resume ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-08-17T08:07:44+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: virtiofs ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-08-17T08:07:45+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Constructing AuthenticAMD.bin ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-08-17T08:07:46+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd-fallback' ***
[2024-08-17T08:07:51+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd-fallback' done ***
[2024-08-17T08:07:51+0000] [ALPM-SCRIPTLET] dracut[I]: Executing: /usr/bin/dracut --hostonly --no-hostonly-cmdline -f /efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd 6.10.5-arch1-1
[2024-08-17T08:07:52+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-ask-password ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-initrd ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-journald ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-modules-load ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysctl ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-sysusers ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-tmpfiles ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-udevd ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: i18n ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: crypt ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dm ***
[2024-08-17T08:07:53+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules ***
[2024-08-17T08:07:54+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: kernel-modules-extra ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: pcmcia ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: systemd-cryptsetup ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: hwdb ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: rootfs-block ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: terminfo ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: udev-rules ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: dracut-systemd ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: usrmount ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: base ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: fs-lib ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including module: shutdown ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Including modules done ***
[2024-08-17T08:07:55+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies ***
[2024-08-17T08:07:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Installing kernel module dependencies done ***
[2024-08-17T08:07:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies ***
[2024-08-17T08:07:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Resolving executable dependencies done ***
[2024-08-17T08:07:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files ***
[2024-08-17T08:07:56+0000] [ALPM-SCRIPTLET] dracut[I]: *** Hardlinking files done ***
[2024-08-17T08:07:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Generating early-microcode cpio image ***
[2024-08-17T08:07:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Constructing AuthenticAMD.bin ***
[2024-08-17T08:07:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Store current command line parameters ***
[2024-08-17T08:07:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files ***
[2024-08-17T08:07:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Stripping files done ***
[2024-08-17T08:07:57+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd' ***
[2024-08-17T08:08:00+0000] [ALPM-SCRIPTLET] dracut[I]: *** Creating initramfs image file '/efi/a3de150f4ba649e5aa43965e592b322b/6.10.5-arch1-1/initrd' done ***
[2024-08-17T08:08:00+0000] [ALPM] running 'eos-reboot-required.hook'...
[2024-08-17T08:08:01+0000] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2024-08-17T08:08:02+0000] [ALPM] running 'gdk-pixbuf-query-loaders-32.hook'...
[2024-08-17T08:08:02+0000] [ALPM] running 'glib-compile-schemas.hook'...
[2024-08-17T08:08:02+0000] [ALPM] running 'gtk-update-icon-cache.hook'...
[2024-08-17T08:08:03+0000] [ALPM] running 'gtk4-querymodules.hook'...
[2024-08-17T08:08:03+0000] [ALPM] running 'rebuild-detector.hook'...
[2024-08-17T08:16:32+0000] [ALPM-SCRIPTLET] tee: /tmp/tmp.0mQliKdbXh/32519: No such file or directory
[2024-08-17T08:16:33+0000] [ALPM-SCRIPTLET]
[2024-08-17T08:16:33+0000] [ALPM-SCRIPTLET] Interrupt signal received
[2024-08-17T08:16:33+0000] [ALPM-SCRIPTLET] tee: /tmp/tmp.0mQliKdbXh/14277: No such file or directory
[2024-08-17T08:16:33+0000] [ALPM] running 'texinfo-install.hook'...
[2024-08-17T08:16:33+0000] [ALPM] running 'update-desktop-database.hook'...
I don’t think it really contains any info that wasn’t in the OP though, you can see it runs the rebuild detector hook at 08:08 and i sent it an interrupt at 08:16.
It’s not like it gave any error messages, it was running, it was just running for far too long.
I would let it error out if it will
Also I notice this. It may not have anything to do with your issue but seems probable
I don’t know if this file is even needed or what it is but it could be a start for the trouble shooting maybe someone like @dalto or @manuel would be of more help with that.
Are you able to run an update again and it shows all it fine and it is updated? Rebooting is okay too?
You can remove rebuild detector if you don’t need it. All it does it look for packages that need to be rebuilt and show you the list.
think it could be an AUR package causing it? is it possible to exclude them?
Hard to say what is causing it since there is no output. You could change the hook to add -v to the command so you could see what it is trying to do when it fails.
