System tray icon for Thunderbird
Has anyone gotten the native system tray to work with Thunderbird 154? Supposedly in 154 there is supposed to be optional system tray integration but I can’t find it. I thought if switching to better bird but now sure If there would be any issues switching back if it doesn’t work. I’ve also tried Systray-X but found it buggy.
what DE/WM are you using?
Shows up here on KDE plasma, but since it has no functionality on Linux (yet) it’s rather useless. Birdtray works here.
plasma
where were you able to find how to enable it?
I don’t find it in the GUI at the moment, but the Internet says it should be mail.biff.show_tray_icon_alway in the advanced settings (Settings → General at the bottom → Config Editor).
git it thanks, actually did see that but like you said it didn’t do anything. Going to give birdtray another try
