Suspend still got stuck unfortunately.
Check out these:
https://www.reddit.com/r/EndeavourOS/comments/x5kr41/amd_gpu_doesnt_let_my_pc_suspend/
https://www.reddit.com/r/Fedora/comments/1gq3o22/freeze_after_suspend/
Yep, a lot of us are having this issue. You can try disabling bluetooth or switching back to a 6.10.x kernel as workarounds. It’s unclear to me if anyone is trying to find the cause and a real fix.
Okay so it seems bluetooth does help, turning it off made suspension work properly.
I guess I’ll keep it disabled then, I never use bluetooth on this anyway so it’s fine.
Thanks for helping me
Perhaps mark this as solved ? If it did resolve your issues without causing additional problems.
