Hi,
I’m having an inconsistent issue with my suspend. Mostly I can suspend just fine but sometimes (like every 4-5 times) my screen goes black as normal, but fans keep spinning and my power button LED stays on. When this happens there is nothing I can do except REISUB. Even waiting an hour does not change the state. I have not found a pattern when this happens.
Here are some journalctl logs: https://pastebin.com/FZpWU6Jh
The log ends with the start of the REISUB procedure.
And here is inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.1.12-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux
root=UUID=4140d0fa-02f5-4b8c-bbf5-6abd7c894597 rw rootflags=subvol=@ quiet
cryptdevice=UUID=6fcf6232-87f8-4c22-baba-3472efeab7e9:luks-6fcf6232-87f8-4c22-baba-3472efeab7e9
root=/dev/mapper/luks-6fcf6232-87f8-4c22-baba-3472efeab7e9
resume=/dev/mapper/luks-6fcf6232-87f8-4c22-baba-3472efeab7e9 loglevel=3
resume_offset=2368768 nowatchdog nvme_load=YES nvidia-drm.modeset=1
Desktop: GNOME v: 43.3 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Desktop Mobo: Micro-Star model: MEG X570 UNIFY (MS-7C35) v: 2.0
serial: <superuser required> UEFI: American Megatrends LLC. v: A.A0
date: 06/22/2021
Battery:
Message: No system battery data found. Is one present?
Memory:
RAM: total: 31.27 GiB used: 5.8 GiB (18.5%)
RAM Report: permissions: Unable to run dmidecode. Root privileges required.
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2461 high: 3601 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3600 2: 2495
3: 2096 4: 2057 5: 3596 6: 2200 7: 2158 8: 2200 9: 3601 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2187 bogomips: 115233
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae
pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Vulnerabilities:
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl
sanitization
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104 [GeForce GTX 1080] driver: nvidia v: 525.89.02
non-free: 525.xx+ status: current (as of 2023-02) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: DP-3,DVI-D-1,HDMI-A-1 empty: DP-1,DP-2
bus-ID: 2d:00.0 chip-ID: 10de:1b80 class-ID: 0300
Device-2: Sunplus Innovation FHD Camera Microphone type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-6.4:8 chip-ID: 1bcf:28c4
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 with: Xwayland v: 22.1.8
compositor: gnome-shell driver: X: loaded: nvidia unloaded: modesetting
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
screens: 1
Screen-1: 0 s-res: 5560x1920 s-dpi: 96 s-size: 1471x508mm (57.91x20.00")
s-diag: 1556mm (61.27")
Monitor-1: DP-3 mapped: DP-4 note: disabled pos: primary,middle-c
model: Dell S2716DG serial: <filter> built: 2018 res: 2560x1440 dpi: 109
gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: max: 2560x1440 min: 640x480
Monitor-2: DVI-D-1 mapped: DVI-D-0 note: disabled pos: bottom-l
model: LG (GoldStar) 23MB35 serial: <filter> built: 2015 res: 1920x1080
hz: 60 dpi: 96 gamma: 1.2 size: 510x290mm (20.08x11.42")
diag: 587mm (23.1") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-3: HDMI-A-1 mapped: HDMI-0 note: disabled pos: top-right
model: LG (GoldStar) 23MB35 serial: <filter> built: 2015 res: 1080x1920
hz: 60 dpi: 95 gamma: 1.2 size: 290x510mm (11.42x20.08")
API: OpenGL v: 4.6.0 NVIDIA 525.89.02 renderer: NVIDIA GeForce GTX
1080/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GP104 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 1-5:3 pcie: chip-ID: 17a0:0120 gen: 3 class-ID: 0300 speed: 8 GT/s
lanes: 16 bus-ID: 2d:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Samson Meteorite condenser microphone type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-6.1:5 chip-ID: 0c76:161f
class-ID: 0300
Device-5: Sunplus Innovation FHD Camera Microphone type: USB
Sound API: ALSA v: k6.1.12-arch1-1 running: yes
Sound Server-2: PipeWire v: 0.3.66 running: yes
Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 27:00.0
chip-ID: 10ec:8125 class-ID: 0200
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global
broadcast: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 28:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IP v4: <filter> scope: global
IP v6: <filter> scope: global
IP v6: <filter> virtual: stable-privacy scope: link
IF-ID-2: srv-eos-l state: unknown speed: N/A duplex: N/A mac: N/A
Message: Output throttled. IPs: 2; Limit: 10; Override: --limit [1-x;-1
all]
WAN IP: <filter>
Bluetooth:
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:2
chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
Logical:
Message: No logical block device data found.
Device-1: luks-6fcf6232-87f8-4c22-baba-3472efeab7e9 maj-min: 254:0
type: LUKS dm: dm-0 size: 1.32 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 1.32 TiB
RAID:
Message: No RAID data found.
Local Storage: total: 2.27 TiB used: 669.39 GiB (28.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: PNY model: CS3030 2000GB SSD
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CS303224 temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Crucial model: CT500P1SSD8
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P3CR021 temp: 42.9 C scheme: GPT
Message: No optical or floppy data found.
ID-1: / raw-size: 1.32 TiB size: 1.32 TiB (100.00%) used: 669.38 GiB (49.6%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6fcf6232-87f8-4c22-baba-3472efeab7e9 label: N/A
uuid: 4140d0fa-02f5-4b8c-bbf5-6abd7c894597
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 6 MiB (1.2%)
fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A uuid: FF05-AEF1
ID-3: /home raw-size: 1.32 TiB size: 1.32 TiB (100.00%)
used: 669.38 GiB (49.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /mnt/backup raw-size: N/A size: 27.93 TiB used: 14.26 TiB (51.1%)
fs: cifs dev: /dev/backup
ID-5: /mnt/docker raw-size: N/A size: 27.93 TiB used: 14.26 TiB (51.1%)
fs: cifs dev: /dev/docker
ID-6: /mnt/media raw-size: N/A size: 27.93 TiB used: 14.26 TiB (51.1%)
fs: cifs dev: /dev/media
ID-7: /mnt/services raw-size: N/A size: 27.93 TiB used: 14.26 TiB (51.1%)
fs: cifs dev: /dev/services
ID-8: /mnt/usr raw-size: N/A size: 27.93 TiB used: 14.26 TiB (51.1%)
fs: cifs dev: /dev/usr
ID-9: /swap raw-size: 1.32 TiB size: 1.32 TiB (100.00%)
ID-10: /var/cache raw-size: 1.32 TiB size: 1.32 TiB (100.00%)
ID-11: /var/cache/pacman/pkg raw-size: 1.32 TiB size: 1.32 TiB (100.00%)
ID-12: /var/log raw-size: 1.32 TiB size: 1.32 TiB (100.00%)
Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: file size: 38 GiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
Unmounted:
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 512 GiB fs: btrfs label: N/A
uuid: 442d0387-f8d4-4ec5-b665-e6b670d02100
ID-2: /dev/nvme1n1p1 maj-min: 259:5 size: 99 MiB fs: vfat label: N/A
uuid: EC75-B0E0
ID-3: /dev/nvme1n1p2 maj-min: 259:6 size: 465.66 GiB fs: bitlocker
label: N/A uuid: N/A
USB:
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-4:2 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0029
class-ID: e001
Device-2: 1-5:3 info: Samson Meteorite condenser microphone type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 56mA chip-ID: 17a0:0120 class-ID: 0300
Hub-2: 1-6:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 1-6.1:5 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:161f class-ID: 0300
Device-2: 1-6.2:6 info: Glorious GMMK Pro type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 320f:5044 class-ID: 0300
Device-3: 1-6.3:7 info: Razer USA Mamba Elite (Wired) type: Mouse,Keyboard
driver: razermouse,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1532:006c class-ID: 0300
Device-4: 1-6.4:8 info: Sunplus Innovation FHD Camera Microphone
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1bcf:28c4 class-ID: 0102
serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip-ID: 1d6b:0003 class-ID: 0900
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 1462:7c35 class-ID: 0300 serial: <filter>
Hub-5: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0608 class-ID: 0900
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-8: 5-1:2 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Hub-9: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.9 C mobo: N/A gpu: nvidia temp: 59 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 21%
Processes: 439 Uptime: 3h 37m wakeups: 1 Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1662 libs: 458 tools: yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.25
I can see a few suspend errors in the log but have no idea what they mean. Any advice is appreciated!
Cheers
