After I updated my system today and rebooted my system keeps on this screen and nothing happens
I tried using a live usb run fsck -r on my partition /dev/sda2 but didn’t worked
Any ideas what I need to do?
Can we see the output of inxi -Fxxxz
You can run it from the live ISO?
Do you have an older nvidia GPU by any chance? nvidia recently dropped support for many cards in the latest drivers.
A post was split to a new topic: Install fails to boot after update
Try with a different kernel.
Provide hardware details and packages that were updated for a start.
Hardware details using inxi
Updated info you should find at the bottom of /var/log/pacman.log
Journal logs and possible xorg logs for a failed boot; chroot into your system from a live environment to get those.
If all else fails to you have a backup you can restore to?
